CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
8366
Highlighted
Beginner
MGBT1 Compatibility
Hello Everyone,
Recently purchased some 1000Base-T Mini-GBIC SFPs (MGBT1) under the impression that they were full-fledged Cisco devices with intent to use them in our 3560G-48TS. As I hotplug them in, I receive the following:
%GBIC_SECURITY_CRYPT-4-VN_DATA_CRC_ERROR: GBIC in port Gi0/48 has bad crc
%PM-4-ERR_DISABLE: gbic-invalid error detected on Gi0/48, putting Gi0/48 in err-disable state
The interfaces do not come online at this point, nor does it seem I can force them to. My research has found mixed feelings on whether this error is show-stopping or not.
I am running the following on my 3560G
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(44)SE6
Does anyone have any input as to whether the MGBT1 can actually (reliably) work with the 3560G and if so, how?
Please let me know if I have forgotten any critical information.
Jeff
3 REPLIES 3
Highlighted
Rising star
Hi Jeffrey
The datasheet for your product which i have copied shows the SFP that are supported on your switch;
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/product_data_sheet09186a00801f3d7d.html
Scroll down to nearly the bottom of that datasheet page and you will see the SFP's appropriate for that model.
The MGBT1 is a SFP that is supported by the Cisco Small Business and Small Business Pro range of product.
But if you want a 1000T  SFP for the 3560G  you need to order the cisco p/n  GLC-T=
Here are some of the SFP's supported by your product, I copied part of the table below from the datasheet;
Highlighted
Thank you, this is the matrix I was trying to find but could not. Just to be clear, does this imply that using the MGBT1 will not work at all or it simply is not supported/recommended? I'm fairly close to believing the former, but I just want to be sure.
Thanks again,
Jeff
Highlighted
Jeffrey there is a interesting link below, please read it carefully, regarding insertion of 3rd party SFP.
referenece is from   http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/prod_qas09186a00801b0971.html
The following link is really handy, showing cisco model and the SFPs supported.
http://www.cisco.com/en/US/products/hw/modules/ps4999/products_tech_note09186a00807a30d6.shtml
