Microsoft Network Load Balancing on the SG-500
I wanted to know if the Microsoft Network Load Balancing can also be configured on the switch SG-500? and if so, how?
chrebert
Level 4
Level 4
From everything I have read about this service, it is independent of hardware, the configuration is all done on the servers themselves.
Source I used:  Microsoft Network Load Balancing Technical Overview
The section on Ease-of-use talks about there being no hardware changes required for this to work.
Hope that helps and thank you for choosing Cisco,
Christopher Ebert - Advanced Network Support Engineer
Cisco Small Business Support Center
*please rate helpful posts*
I refer to the document loaded.
The commands for configuring multicast on Catalyst switches are also applicable series on small business?
I do not have the ability to remotely access the switches of the customer and then check with your hand.
From looking over your document the unicast solution won't be a problem, but with the multicast setup the issue you run into is needing to set the same MAC address statically on two different interfaces (mac−address−table static 0100.5e11.1111 vlan 200 interface fa2/3 fa2/4).  This is something you cannot go on the SG500s.
I am just going off of these documents, since I cannot really test this here in my lab, but I would say if you want to set it up like that you would need an enterprise switch.
Christopher Ebert
