11-22-2010 11:54 AM
For part# MGBSX1, does this support fiber with a core size of:
a. 62.5 microns
b. 50 microns
c. both.
I was unable to find this information at the two below urls:
http://www.cisco.com/en/US/products/hw/modules/ps4999/products_qanda_item09186a0080abed87.shtml
http://www.cisco.com/en/US/partner/prod/collateral/modules/ps9934/data_sheet_c78-552203.html
Thanks for your help,
j•murg
Solved! Go to Solution.
11-24-2010 11:29 AM
11-24-2010 11:29 AM
John
I checked and the cable size is 62.5 multimode.
11-24-2010 02:48 PM
Hi John,
The MGBSX1 actually will work with both 50um and 62.5um Multimode cable.
regards
Dave Hornstein
11-24-2010 03:42 PM
Dave
Below is the screenshot with the specifications that I found hope this helps.
Specifications | |
Model Number | MGBSX1 |
Standards | Compliant with Specifications of SFP Transceiver MSA Specification |
Cabling Type | 850 nm (850nm TYP., 830-860nm) MMF (Multi-Mode Fiber) MMF: 62.5/125um fiber @ 160 MHz/km to 220m minimum distance, 62.5/125um fiber @ 200 MHz/km to 275m minimum distance, 50/125um fiber @ 400 MHz/km to 500m minimum distance, 50/125um fiber @ 500 MHz/km to 550m minimum distance |
Environmental | |
Dimensions | 0.33" x 0.53" x 2.22" |
WxHxD | (8.5 mm x 13.4 mm x 56.5 mm) |
Unit Weight | 0.63 oz. (0.02 kg) |
Power | Transmitter Spec: Power : -9.5 – -4 dBm, Reciever Spec:Sensitivity: -20 - -17dBm, 8 Input Power: -20 – -17 dBm, Stress Sensitivity: 50/125 um: -13.5dBm, 62.5/125 um: -12.5dBm, 3.3V Power Supply |
Operating Temperature | 0ºC to 40ºC (32ºF to 104ºF) |
Storage Temperature | -20ºC to 70ºC (-4ºF to 158ºF) |
Operating Humidity | 0% to 85%, Non-Condensing |
Storage Humidity | 5% to 90%, Non-Condensing |
