CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
760
Highlighted
Beginner
Port isolation between two SRW swiches connected through fiber?
Hi guys,
i have one SRW2024P connected through fiber to SRW2048. I would like to create isolated link between these two switches consisting of at least one isolated port at each switch. Can this SRWs do this?
Alternatively i need on the SRW2048 side few PoE ports so do you know any 16+ port PoE switch that can do this?
THX for answer.
Everyone's tags (3)
1 REPLY 1
Rising star
Re: Port isolation between two SRW swiches connected through fib
Do you mean you want a port on each switch to be able to communicate with each other but not with any other ports on the switches ?
i.e PC host at 192.168.1.3 on  port 2 on switch 1,  to be able to ping  a IP host at 192.18.1.2 on  switch 2 port 3 ?
If this sort of functionality is required you want to create a new vlan to the switch.  If it is not the case please explain in more detail what you want and ignore the following.
regards Dave
Om my srw2008P i would do the following, i guess your interface is almost identical to my switch GUI interface.
step 1  create a vlan, maybe vlan 2
[make sure you scroll down to the bottom of the page at each step and save changes]
step 2. alter alter port x to be a untagged member of vlan 2
step 3 modify the vlan interface setting  on both switches to make the fiber uplink port a trunk in vlan 2.
