CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
804
Potential bug IR1101 - Reload command
ir1101#reload
Proceed with reload? [confirm]^S
ir1101#reload
ir1101#reload
ir1101#
ir1101#reload
ir1101#reload
ir1101#
It looks like ^S is appended and it blocks actual reload.
not sure if its a bug or there is config problem.
2 REPLIES 2
Highlighted
VIP Collaborator
Re: Potential bug IR1101 - Reload command
 - Check sanity of your current terminal-operator equipment, possibly try another solution to access the device, check if the problem persists.
 M.
Highlighted
Hall of Fame Community Legend
I've read about this. This is a known bug.
I can't find the bug ID from the email.
Upgrade the firmware is the only way to go.
