09-06-2012 11:21 PM
Good Day. I would like to ask the correct part number of the power adapter on WAP4410N?
Solved! Go to Solution.
09-06-2012 11:34 PM
Hi Roy, there is not a part number available for the WAP4410N. The device does use 12 volt, 1 amp adapter.
The only power adapter sku there is, is for the SPA phones which is the PA-100-xx, the 5 volt, 2 amp adapters.
-Tom
Please rate helpful posts
09-07-2012 12:04 AM
Rey, the original package content contains the adapter. You may try to call sbsc requesting an adapter. In the past we have had customers have a rma processed, remove adapter and return the replacement device.
09-06-2012 11:34 PM
-Tom
09-06-2012 11:41 PM
Hi Thomas,
So that would mean the power adapter is not orderable from Cisco. Chances are client will use a third party power adapter that would meet the specifications of the original power adapter.
09-07-2012 12:04 AM
09-07-2012 12:37 AM
Hi Thomas,
Thank you very much for your assistance. We will coordinate with our team here so as to assist the client.
Best Regards,
