CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
242
Beginner
privilege level
Hi All,
How can a privelege level which give you the permission to execute only 'show running-config ' command be set on SG series switches?
Thank you in advance,
Tamas
Highlighted
Re: privilege level
Hello Tamas,
Happy New 2019 Year!
Download the CLI guide for the Sx300 switches:
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/CLI_300.pdf
page 24 - User (Privilege) Levels
Hope it helps.
Cheers,
Mike
Beginner
Re: privilege level
Is it somehow possible to define your own privilege level different from 1,7 or 15?
VIP Advocate
Re: privilege level
Beginner
Re: privilege level
VIP Advocate
Re: privilege level
Not for these device i am aware of.
BB
*** Rate All Helpful Responses ***
Beginner
Re: privilege level
Could it be realized with a tacacs/radius server neither?
VIP Advocate
Re: privilege level
yes i support other post you can use radius/tacacs/acs -  can do this job for you, since this SMB and only 1 router not make any sense for business case to have Radius server.
but options available many if you can able to install another component for this task.
BB
