CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
868
Beginner
Problem with DHCP
I created 4 VLANS in my switych cisco SF300-48PP
the switch is connected to a 192.168.1.1 ADSL router
VLAN 1 address 192.168.1.6 DHCP 192.168.1.7-192.168.1.63 / MASK 255.255.225.192
VLAN 2 address 192.168.1.65 DHCP 192.168.1.66-192.168.1.128 / MASK 255.255.225.192
VLAN 3 address 192.168.1.130 DHCP 192.168.1.7-192.168.1.190 / MASK 255.255.225.192
VLAN 1 address 192.168.1.192 DHCP 192.168.1.193-192.168.1.250 / MASK 255.255.225.192
My problem what I have the internet only in the VLAN1 not in the others
Cordially
1 ACCEPTED SOLUTION
Beginner
Re: Problem with DHCP
Problem solved, it was necessary to put back the mask of the Modem ADSL with 255.255.255.0 thanks for everyone cordially
35 REPLIES 35
VIP Advisor
is this typo or why there 2 VLAN 1 available here ?
By default VLAN 1 is Nat , you need to configure other VLAN to NAT
below guide help you:
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
BB
*** Rate All Helpful Responses ***
Beginner
vlan4 not vlan1
VIP Advisor
ok, then we would be more interested to see your NAT config along with routing.
BB
Beginner
I saw the document but I can not find it or configure NAT
on the other hand I configure my switch by program Managed SWITCH
cordially
VIP Advisor
Can you post the configuration to have look.
BB
Beginner
Please make sure your ADSL Router LAN Pool IP subnet mask is similar to the VLAN 1 (VLAN 10 as per the screenshot) IP Subnet, after that you need to apply the static routes (reverse route) on the ADSL Router for the remaining VLANs configured on the Switch towards the IP 192.168.1.6 (assuming that 192.168.1.6 IP is directly communicating with your ADSL Router (192.168.1.1). Also make sure you have configured the DNS settings on the DHCP pools (you may try 8.8.8.8).
In case ADSL Router IP configured as 192.168.1.1 /24 then it will better if you can use the IP subnet like 192.168.2.0 /24, 192.168.3.0 /24 for the respective VLANs on the SF300 Switch and accordingly apply the reverse route on your ADSL Router to allow the Internet Access for the other VLANs on the Switch.
On the attached screenshots VLAN are showing as VLAN 10,20,30 & 40. FE1 port is showing ‘Tagged’ and remaining ports are ‘Untagged’. It will be better if you can share the ‘Port VLAN Membership’ scrennshot.
In case your ADSL Router supports 802.1Q Trunking then you can use the ‘Tagged’ option otherwise you may keep the port settings as ‘Untagged’.
Beginner
Highlighted
Beginner
Enthusiast
As i understood from this IPs,
You need to have IP address for each vlan in switch. That IP will be the gateway for those VLANs.
Then add default route to adsl router IP address using static routes.
At ADSL router you should add static routes for each VLAN network,  Which are pointed to switch VLAN 1 IP
Beginner
Thank you in advance ,
really what I was doing but unfortunately I can not.
I have a DLINK ADSL Modem,
I send you a screenshot for the modem and send me an example of a route
VIP Advisor
This example : you can do same for all VLAN and test and advice.
Destination address : 192.168.1.65
subnet sk MASK 255.255.225.192
gateway : 192.168.1.6 ( as per your information the router IP)
BB
Beginner
Enthusiast
Network address is 192.168.1.64
Subnet
255.255.255.192
