CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
1203
Beginner
Re: Problem with DHCP
i made the roads, now i pingue the router but i still do not have the internet in VLANs 20,30, and 40
I noticed again that I have too much loss by pinging 192.168.1.1,
Beginner
Enthusiast
have you added default route in switch directed to adsl router? also 3 static routes which destined to VLANs at adsl router. also check for packet drops or errors in connected interface
Beginner
I send you what I did, in the configuration, concerning the losses I started to have as soon as I changed the mask of the Modem ADSL in 26
I put the cable that connects my cisco switch and the ADSL Modem in ports N ° 1
Enthusiast
in switch, add below route.
destination - 0.0.0.0
subnet - 0.0.0.0
next hop - 192.168.1.1
after that user traffic will move in to adsl router and return back for VLANs
Beginner
Still no internet in other Vlans
VIP Advisor
Can you post all your settings from you DLINK router wan side and Lan side setup screen shot.
BB
*** Rate All Helpful Responses ***
Beginner
Highlighted
Enthusiast
can you ping to 192.168.1.1 from other VLANs?
Beginner
yes
Now I ping external adress for Model DLINK but I dont have Internet with VLAN 20/30/40
Enthusiast
that is bit strange. if default route and internal routes are added it should be able to access internet. can you try traceroute and check where is it getting dropped?
Beginner
41.188.89.113 external Ip adress for dlink
VIP Advisor
can you able to ping from VLAN 10, 20, 30 to 8.8.8.8 or 1.1.1.1
also post traceroute information to 8.8.8.8 1.1.1.1
what is the DNS Setting at PC ?
BB
Beginner
I do not think it's a DNS problem, because from VLAN 10 I do not have a problem
from VLAN 20,30,40 I can go to the external address of the Modem but I do not go out anymore it's like my vlan addresses are not routable
for the DNS I use 8.8.8.8 I even used other DNS of the operator who walk but without success
Enthusiast
Its like routes working well. Check dna. Set em to 8.8.8.8 or 1.1.1.1
