Problem with SG350XG-24F 24-Port 10G SFP+ Ports
all ports in specs must support 10G but i have some port i can't make 10G either from web or CLI and from CLI when executing command it shows Port  can not be configured to speed 10G
Hi again Abdalnoor,
That is why you cannot go to 10gigabit - your SFP (SFP-1000-LX) is a gigabit one.
Try to replace it with 10gigabit - as per datasheet:
https://www.cisco.com/c/en/us/products/collateral/switches/350x-series-stackable-managed-switches/datasheet-c78-735986.html
SKU
Media
Speed
Maximum distance
SFP-H10GB-CU1M=
Copper coax
10 Gbps
1 m
SFP-H10GB-CU3M=
Copper coax
10 Gbps
3 m
SFP-H10GB-CU5M=
Copper coax
10 Gbps
5 m
SFP-10G-SR=
Multimode fiber
10 Gbps
26 m to 400 m
SFP-10G-LR=
Single-mode fiber
10 Gbps
10 km
SFP-10G-SR-S=
Multimode fiber
10 Gbps
26 m to 400 m
SFP-10G-LR-S=
Single-mode fiber
10 Gbps
10 km
Hope it helps
Mike
8 Replies 8
marce1000
 - So , what happens then or what kind of error are you getting when you try this ?
   M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
it shows Port can not be configured to speed 10G and in web browser only shows 1000 there is no 10000
 - Check if this article can help you :
             https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-350x-series-stackable-managed-switches/smb5795-sg350x-sx550x-unable-to-change-xg-port-settings-on-a-switch.html
 M.
i have saw this topic and didn't found something that can help me , this image attached to port configuration available
 - Try using latest firmware for your device anyway if not yet  done, then have a drive-through test by connecting a 10-Gb SFP+ with a connection, sometimes speeds get auto-configured. Check if the device reacts 'wisely' if  get's a 10 Gb connection to handle.
 M.
mihail_ip
Hello Abdalnoor,
what shows the following command:
switch# show inventory teX/0/X
where X is the port number in question
PID: SFP-1000-LX VID: Information Unavailable
Hi again Abdalnoor,
SKU
Media
Speed
Maximum distance
SFP-H10GB-CU1M=
Copper coax
10 Gbps
1 m
SFP-H10GB-CU3M=
Copper coax
10 Gbps
3 m
SFP-H10GB-CU5M=
Copper coax
10 Gbps
5 m
SFP-10G-SR=
Multimode fiber
10 Gbps
26 m to 400 m
SFP-10G-LR=
Single-mode fiber
10 Gbps
10 km
SFP-10G-SR-S=
Multimode fiber
10 Gbps
26 m to 400 m
SFP-10G-LR-S=
Single-mode fiber
10 Gbps
10 km
Hope it helps
Mike
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
