CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
843
Problem with SG350XG-24F 24-Port 10G SFP+ Ports
all ports in specs must support 10G but i have some port i can't make 10G either from web or CLI and from CLI when executing command it shows Port  can not be configured to speed 10G
1 ACCEPTED SOLUTION
Hi again Abdalnoor,
That is why you cannot go to 10gigabit - your SFP (SFP-1000-LX) is a gigabit one.
Try to replace it with 10gigabit - as per datasheet:
https://www.cisco.com/c/en/us/products/collateral/switches/350x-series-stackable-managed-switches/datasheet-c78-735986.html
SKU
Media
Speed
Maximum distance
SFP-H10GB-CU1M=
Copper coax
10 Gbps
1 m
SFP-H10GB-CU3M=
Copper coax
10 Gbps
3 m
SFP-H10GB-CU5M=
Copper coax
10 Gbps
5 m
SFP-10G-SR=
Multimode fiber
10 Gbps
26 m to 400 m
SFP-10G-LR=
Single-mode fiber
10 Gbps
10 km
SFP-10G-SR-S=
Multimode fiber
10 Gbps
26 m to 400 m
SFP-10G-LR-S=
Single-mode fiber
10 Gbps
10 km
Hope it helps
Mike
8 REPLIES 8
marce1000
VIP Advisor
 - So , what happens then or what kind of error are you getting when you try this ?
   M.
it shows Port can not be configured to speed 10G and in web browser only shows 1000 there is no 10000
i have saw this topic and didn't found something that can help me , this image attached to port configuration available
 - Try using latest firmware for your device anyway if not yet  done, then have a drive-through test by connecting a 10-Gb SFP+ with a connection, sometimes speeds get auto-configured. Check if the device reacts 'wisely' if  get's a 10 Gb connection to handle.
 M.
mihail_ip
Beginner
Hello Abdalnoor,
what shows the following command:
switch# show inventory teX/0/X
where X is the port number in question
PID: SFP-1000-LX VID: Information Unavailable
Hi again Abdalnoor,
SKU
Media
Speed
Maximum distance
SFP-H10GB-CU1M=
Copper coax
10 Gbps
1 m
SFP-H10GB-CU3M=
Copper coax
10 Gbps
3 m
SFP-H10GB-CU5M=
Copper coax
10 Gbps
5 m
SFP-10G-SR=
Multimode fiber
10 Gbps
26 m to 400 m
SFP-10G-LR=
Single-mode fiber
10 Gbps
10 km
SFP-10G-SR-S=
Multimode fiber
10 Gbps
26 m to 400 m
SFP-10G-LR-S=
Single-mode fiber
10 Gbps
10 km
Hope it helps
Mike
