04-15-2020 05:45 AM - edited 04-15-2020 05:45 AM
all ports in specs must support 10G but i have some port i can't make 10G either from web or CLI and from CLI when executing command it shows Port can not be configured to speed 10G
Solved! Go to Solution.
04-19-2020 02:53 AM
Hi again Abdalnoor,
That is why you cannot go to 10gigabit - your SFP (SFP-1000-LX) is a gigabit one.
Try to replace it with 10gigabit - as per datasheet:
SKU | Media | Speed | Maximum distance |
SFP-H10GB-CU1M= | Copper coax | 10 Gbps | 1 m |
SFP-H10GB-CU3M= | Copper coax | 10 Gbps | 3 m |
SFP-H10GB-CU5M= | Copper coax | 10 Gbps | 5 m |
SFP-10G-SR= | Multimode fiber | 10 Gbps | 26 m to 400 m |
SFP-10G-LR= | Single-mode fiber | 10 Gbps | 10 km |
SFP-10G-SR-S= | Multimode fiber | 10 Gbps | 26 m to 400 m |
SFP-10G-LR-S= | Single-mode fiber | 10 Gbps | 10 km |
Hope it helps
Mike
04-15-2020 08:37 AM
- So , what happens then or what kind of error are you getting when you try this ?
M.
04-15-2020 09:22 AM
04-16-2020 01:37 AM
- Check if this article can help you :
M.
04-16-2020 06:16 AM
04-16-2020 10:22 AM
- Try using latest firmware for your device anyway if not yet done, then have a drive-through test by connecting a 10-Gb SFP+ with a connection, sometimes speeds get auto-configured. Check if the device reacts 'wisely' if get's a 10 Gb connection to handle.
M.
04-18-2020 10:19 PM
Hello Abdalnoor,
what shows the following command:
switch# show inventory teX/0/X
where X is the port number in question
04-19-2020 01:39 AM
PID: SFP-1000-LX VID: Information Unavailable
04-19-2020 02:53 AM
Hi again Abdalnoor,
Hope it helps
Mike
