09-04-2013 07:41 AM
Is it possible to configure QinQ tunnels in switches at small business line? What is the procedure to configure to SF300? The switches will be connected at the network edge of the customers.
09-04-2013 08:18 AM
Hi yes, the terminology is "customer port"
To configure it is easy enough, go to vlan management -> interface setting -> edit a port and choose customer port.
-Tom
Please mark answered for helpful posts
03-04-2014 01:36 AM
Hi! And what after? How to insert e.g. 11,12,13 in 10?
03-04-2014 03:18 PM
The switch doesn't originate the second dot1q tags it honors them. So if you have Vlan 100:1 and Vlan 100:2 they will remain separate.
-Tom
http://blogs.cisco.com/smallbusiness/
03-04-2014 08:12 PM
not good. Thank you. I see I must make trunk to the cisco router and set the second tag on my vlans. Then set port in customer mode on SF300 and sent it from router to the provider.
03-05-2014 06:02 AM
i am disappointed that 2960 does not support it to (
