07-22-2014 10:01 AM
Can anyone tell me if there is an equivalent CLI command to reset an interface configuration to default?
In IOS it is "default interface <interface>" which removes all configuration from that switch port. I don't seem to be able to find the same in the SG series CLI.
Rob
07-22-2014 11:19 AM
Hello Rob,
There isn't an equivalent command on the SG series switches, but I will be bringing it up as a feature request, because it would be quite useful.
Until then the only way to reset a port would be to use all of the no versions of the commands, which I know can be a bit of a pain.
Thank you for choosing Cisco,
Christopher Ebert - Advanced Network Support Engineer
Cisco Small Business Support Center
*please rate helpful posts*
03-13-2015 05:16 AM
03-17-2015 04:56 AM
We'll check with the switch product team.
Thanks.
Yiu Kay Lee
Concentrix at Cisco
.:|:.:|:. CISCO | Yiu Kay Lee | Network Engineer | SMB Presales | yiulee@cisco.com
02-20-2017 07:43 AM
I have this difficulty in performing the same procedure.
Default ports
Does cisco have any feedback on this topic?
CISCO SERIE GS300
DON'T HAVE -> (DEFAULT) INTERFACE GEXX
att,
JODSON MARTINS
06-02-2017 12:45 PM
any news?
hard to believe that default is missing
BR
03-19-2015 05:40 AM
Was informed that default interface CLI command feature is not in the road-map.
Thanks.
Yiu Kay Lee
Concentrix at Cisco
05-16-2018 04:55 AM
Here we are 3 years later. Can we get it on the roadmap? The No commands unfortunately don't clear all the garbage automatically created.
04-24-2019 05:44 AM
Please add this command !
01-06-2020 01:41 PM
When to expect this feature? :(
03-04-2020 04:05 AM
use this command : no macro auto smartport
