09-27-2017 02:04 AM - edited 03-21-2019 11:16 AM
Is there a command to reload only one Stack-Member?
Switchtype is SG550XG-24T
Command which works with a 3750-Stack "reload slot X" is not available.
Solved! Go to Solution.
10-19-2017 07:21 AM
Hi Samuel,
There is no such CLI command and no such feature impeded in the Web GUI.
You can do so only manually or reboot the whole stack.
Regards.
10-19-2017 06:15 AM
My name is Rozana and i am an engineer from the Small Business Team.
Unfortunately not all commands that are available on the catalyst series are available on the SMB switches.
For future reference, for all available commands, please refer to the CLI guide of the SG550 series:
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/550xseries/cli_guide/CLI_SG550XG_2_1_0_x.pdf
Regards.
10-19-2017 07:01 AM
Hello Rozana,
thanks for your reply.
Yes, clear that not all commands from a catalyst are available.
I also know and checked the CLI Guide. But I couldn't find an answer to my question.
Is it possible to reload only one specific stack-member?
Best regards,
Samuel
10-19-2017 07:21 AM
Hi Samuel,
Regards.
10-19-2017 09:28 AM
OK, thanks!
So, unfortunately there is no way to update the firmware remote without downtime of the stack.
