03-06-2013 11:00 AM
I have a SWR 2048 switch that has started to make some noise - I suspect one of the fans is starting to go. It looks like the fans are from Sunon, 40mm x 40mm x 20mm, 3 pin, 12v.
Does anyone know the model number or a good source for a replacment fan?
Solved! Go to Solution.
03-06-2013 01:55 PM
Michael, I believe this is a DC fan
I think this the model/spec that you need.
MB40201V2-000U-A99 | 40X40X20 | 12 | 0.050 | 0.60 | 6200 | 7.7 | 0.16 | 21.0 |
-Tom
Please mark answered for helpful posts
03-06-2013 01:27 PM
Hi Michael, unless you're certain the warranty has ended on the switch, I'd recommend to call the SBSC for a RMA. If you open the case, your warranty is void.
Here is the Sunon website if you're warranty has expired...
-Tom
03-06-2013 01:38 PM
My warranty has long ended. All I need to do is replace a $10 fan. I did contact Cisco but they kept trying to sell me a new $1000 switch.
I am trying to find the correct replacement fan - which has been a challenge. I could find a fan that would fit, but would likely have to reconfigure the pin arrangement in the connector.
Which Sunon fan would work for this switch?
03-06-2013 01:55 PM
-Tom
03-06-2013 02:17 PM
Thanks Tom
