02-14-2014 05:02 AM
Dear Friends,
I have two chose a switch between two configuration. Can any one tell me which configuration provides better performance -
Option 1 -
Forwarding bandwidth (switching fabric capacity) - 16 Gbps
Forwarding Rate (switching throughput using 64-Byte Packet size) - 6.5 Mpps
DRAM - 64 MB
Option 2 -
Forwarding bandwidth - 10 Gbps
Forwarding Rate (switching throughput using 64-Byte Packet size) - 6 Mpps
DRAM - 128 MB
Please help in the selection with relevent technical reason.
SY
Solved! Go to Solution.
02-15-2014 11:14 AM
satyajeet,
Based on the numbers you presented only I would go with Option 1. It appears to have higher Forwarding Bandwidth/Rate per port if each switch has 24 ports. It's a little strange that Option 2 has more DRAM yet less switching fabric capacity and throughput. I would be interested in knowing the model number of each switch so I could do more research.
- Marty
02-14-2014 10:24 AM
satyajeet,
Do the switches have an equal number of ports?
It appears that the first one has 8 ports and the second has 5 based on the Forwarding bandwidth.
Are they Cisco models?
- Marty
02-15-2014 12:36 AM
Dear Marty,
Both the switches are of 24 port - 10/100. and rest entire configuration is same in both the switches apart from the differences mentioned above. Please advice me in the selection between these two options. Yes both are of Cisco Model.
02-15-2014 11:14 AM
satyajeet,
- Marty
02-14-2014 03:29 PM
Before I could give you an answer, I have a good question for you: What EXACTLY are you trying to achieve?
