04-09-2013 11:47 AM
Are the MAC Address Tables managed per VLAN? We need to have the VLAN work with a MAC address that is also on a different VLAN.
We are testing a device that has 4 ethernet ports, each having a different IP Address, but they all share the same MAC address. so i would like to be able to have 4 individual VLANS in the switch for testing.
So the need is a switch that manages the MAC address's per VLAN not globally by the switch. Does the Series 300 do this or is there another recommendation for a switch.
Dave
04-11-2013 03:53 AM
Hello Dave,
As you probably noticed small business switches 300 series or even 500 series do not support MAC address table per VLAN.
This is possible on IOS switches only, such as Catalyst 6500: http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801c9b4e.shtml
Aleksandra Dargiel
04-11-2013 08:00 AM
Good morning
Hi dave, thanks for using our forum, my name is Johnnatan and I am part of the Small business Support community. To add to aleksandra´s post, the SMB switches doesn´t have that features, the only models that supports MAC address table per VLAN are the enterprise series that have IOS
I hope you find this answer useful,
“Please rate useful posts so other users can benefit from it”
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
04-18-2013 01:12 AM
Hi Dave:
Series 300 does support IVL, you can see mac address table below from switch console:
switch8c5fa6#
switch8c5fa6#
switch8c5fa6#show mac address-table dy
Aging time is 300 sec
Vlan Mac Address Port Type
1 00:26:0a:4c:d2:04 gi1/13 dynamic
1 00:50:56:95:41:81 gi1/13 dynamic
1 e4:1f:13:77:9f:07 gi1/13 dynamic
1 f4:ea:67:8c:b2:b6 gi1/13 dynamic
101 00:11:11:11:11:11 gi1/21 dynamic
102 00:11:11:11:11:11 gi1/22 dynamic
103 00:11:11:11:11:11 gi1/23 dynamic
104 00:11:11:11:11:11 gi1/24 dynamic
You can see different vlans (101-104) learned same MAC address which matches your posted request.
04-18-2013 07:26 AM
The switch supports mac address table per vlan.. it doesn't support pipe or inc/exc/beg toggles, etc.
switchce82d3#show mac address-table vlan 1
1 00:22:58:97:80:76 fa5 dynamic
1 00:26:f2:ad:59:f2 fa5 dynamic
1 10:8c:cf:ce:82:d3 0 self
1 18:87:96:b6:9c:52 fa5 dynamic
1 58:6d:8f:46:46:f6 fa5 dynamic
1 64:31:50:1c:50:d3 fa8 dynamic
1 88:53:2e:57:a3:f5 fa5 dynamic
1 a8:26:d9:57:7e:96 fa5 dynamic
switchce82d3#show mac address-table vlan 2
2 00:26:0b:0d:82:11 fa2 dynamic
switchce82d3#show mac address-table ?
count MAC addresses count
dynamic dynamic addresses
secure Show secure addresses
static Show static addresses
vlan Specific VLAN
interface Specify an interface ID. The interface ID can be one
of the following types: Ethernet port or Port-channel
address Specific MAC address
-Tom
Please mark answered for helpful posts
04-25-2013 01:56 AM
I have similar requirements for the switch. Since now 2 different opinions have been posted. Hmm... which is more convincing?
I thought all modern manageable switches performs full isolation of VLANs - they behave like separate physical switches (so assumption about separate lookup tables) - having the same MAC address on different VLANs at the same time does not confuse them.
Best regards,
Lukasz
04-25-2013 03:37 AM
The first 2 posts are saying the switch itself has only one mac.
04-25-2013 04:59 AM
Hi Lukasz,
Following the whole confusion on this post I have done the following test which was successful. Please let me know if this is not what you are trying to do.
2 PC with the same MAC address but 2 different IP
connected to 2 different ports in 2 different VLANs:
switch0d810b#show arp
Total number of entries: 3
VLAN Interface IP address HW address status
vlan 1 gi1 192.168.1.100 00:1e:33:56:b5:a9 dynamic
vlan 2 gi2 192.168.2.100 00:1e:33:56:b5:a9 dynamic
vlan 3 gi3 192.168.3.100 00:22:64:c1:14:9a dynamic
switch0d810b#show mac address-table
1 00:1e:33:56:b5:a9 gi1 dynamic
1 00:26:0b:0d:81:0b 0 self
2 00:1e:33:56:b5:a9 gi2 dynamic
3 00:22:64:c1:14:9a gi3 dynamic
tested with ping between those 2 PC as well as from the 3rd one (port gi3) and switch itself work as expected
for your reference switch configuration in layer 3 was as simple as below:
switch0d810b#
interface vlan 1
ip address 192.168.1.254 255.255.255.0
no ip address dhcp
interface vlan 2
ip address 192.168.2.254 255.255.255.0
interface vlan 3
ip address 192.168.3.254 255.255.255.0
interface gigabitethernet1
switchport mode access
interface gigabitethernet2
switchport access vlan 2
interface gigabitethernet3
switchport access vlan 3
exit
Aleksandra
04-25-2013 05:49 AM
Hi Aleksandra,
The example you provided demonstrate very well what I'm trying to do. My team is working on device (I'm embedded SW/HW engineer with some CCNA / IT administration background in the beginnings on my carieer :-)), with few Ethernet interfaces with the same MAC (in fact those interfaces will be made by some tuned Ethernet switch chip - it's why MAC addresses will be duplicated).
I'd like to buy a switch which will let me test those devices. It seems Cisco SG300-28 fulfills my requirements - I'm going to buy it.
Thank you very much!
04-25-2013 05:54 AM
In other words - it is not possible to assign different MAC address for the switch on each VLAN. Did I understand well?
04-25-2013 06:21 AM
Hi Lukasz, the switch should only display 1 system MAC address regardless of VLAN. Each port does have a MAC address however those should not be ARP or be included in a bridge table.
-Tom
04-25-2013 06:47 PM
Hi Lukasz,
Tom's explaination is correct. and let me explain more:
Vlan by itself is virtual, and has no MAC as identification.
VLAN interface with IP address has MAC, which is the system MAC that Tom mentioned.
System MAC is used as destination MAC for the switch when you ping the switch or use switch as IP gateway.
Each physical port has its MAC. SMB switch cannot change these port MAC.
You can see these MAC as source MAC by capturing Spanning Tree BPDU packet coming out from each port.
08-16-2013 12:13 AM
Hi All,
i have the same query:
can i have two PC has the same mac-address and different IP address from the same subnet.
if yes without issue, does switch 2950 or higher support this feaure or do i need specific configuration on the switch?
thanks in advanced.
08-16-2013 10:22 PM
if the 2 PC are in same vlan , no,
because switch need to bind MAC to fixed port+vlan to send the packet.
same MAC makes confusion and packet will get lost.
if the 2 PC are in difference vlan, yes
08-18-2013 12:44 AM
Hello jialbert,
Thanks alot fot this information.
