CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
4324
brent Hanson
Beginner
SF 300-24 Switch and IP Phones
I didn't know whether to place this in here or in the IP telephony section. Anyway, we recently had some lightning damage a switch. It's in a little used building (four computers, two phones) so instead of replacing it with the same switch (Catalyst 29xx series), I did a little research and found the SF-300-24 should be able to do the same thing for much cheaper.
Anyway, I was a little surprised when I got the switch and couldn't do much from the command line. Here's a snippet of my config from the old router...
interface FastEthernet 0/1
  switchport access vlan 2
  switchport mode trunk
  switchport voice vlan 2
(other ports same)
interface vlan1
  ip address 100.234.10.4 255.255.252.0
  no ip directed-broadcast
  no ip-route cache
Anyway, I am trying to get the new switch to work and I'm having trouble getting the ip phones to work. I've given all ports access to VLAN 1 (default) and VLAN 2 which is the vlan our core router uses for the ip phone network. Using a Cisco 7940 phone (along with Cisco Unified CM version 7.1.3.21901-1). When I plug a computer into the new switch (which I've programmed to use the same ip as the old switch), I'm able to browse internet, access network, etc. However, when I plug a phone in, it constantly says "Configuring IP" - it's not grabbing any of the correct settings (ip address is in the 100.234.8.x and not in the 100.234.5.x that phones should be getting). TFTP server is blank (should be 100.234.7.250) and default router shows the gateway and not what other phones are grabbing (100.234.5.50).
Any ideas?
Brent
1 REPLY 1
David Hornstein
Rising star
Hi Brent,
Don't really want to underestimate the value of catalyst switches with their extensive command line flexability, debugging etc..
But to answer your question, here  is my factory defaulted switch  configuration below which is using version 1.1 of the firmware.
What is presented below is the  configuration that the SG300 switch put together as a result of advertising in my UC500 what the voice VLAN is via CDP.
The only thing I manually configured onto my switch are the commands in red. G1, G2 and G5 have IP phones connected to them
User Name:cisco
Password:*****
switch0fdcfd#sh run
interface range gi1-2,gi5
storm-control broadcast enable
exit
interface gigabitethernet1
storm-control broadcast level 10
exit
storm-control include-multicast
exit
interface gigabitethernet2
exit
exit
interface gigabitethernet5
exit
exit
spanning-tree portfast
exit
interface  gi10
spanning-tree link-type point-to-point
exit
port security mode max-addresses
exit
port security max 10
exit
port security discard trap 60
exit
vlan database
vlan 100
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
hostname switch0fdcfd
no passwords complexity enable
ip telnet server
macro description ip_phone_desktop
exit
macro description "ip_phone_desktop | no_ip_phone_desktop | ip_phone_desktop"
exit
exit
interface gigabitethernet10
macro description "switch | no_switch | switch"
exit
!next command is internal.
macro auto smartport dynamic_type ip_phone_desktop
switchport trunk allowed vlan add 100
exit
exit
exit
macro auto smartport dynamic_type switch
exit
switch0fdcfd#
  I had used CCA  to configure that option, you could probably use Cisco Configuration Professional (CCP) if you are not using a UC500  .
UC500 expansion port tio my switch
interface FastEthernet0/1/8 --- connected to SRW2008P-K9-NA (SG300-10P)
switchport voice vlan 100
macro description cisco-switch
have fun
regards Dave
