SF-300-48P POE is power cycling
I have a SF-300-48P that is power cycling all POE ports (in use) exactly every 30 minutes. The other older cisco POE switches we were replacing did not have this issue. We have about 40 cisco SPA942 IP phones connected to it. Power consumption is about 175 watts total.
This is my second switch, previously tried a SG500X-48P with the same result.
Any ideas how to stop it from cycling?
Thanks for the help,
David
27 Replies 27
Tom Watts
Hello David, what version firmware is the switch running?  If you remove any amount of phones does the switch stop dropping?
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Version: 1.1.2
To add to the info, I just realized, one of the old 24 port switches (still in use) is cycling its ports as well. This switch is plugged into the SF-300 via a standard 10/100 port.
I actually do recall this happening with the first new switch i tried as well. After removing the new switch and placing the other old switch back in place the power cycling stopped. Seems like less of a switch issue and maybe a power issue but I don't see why the 2 old 24 port switches play nice together.
More info: the VOIP phones register offsite at the ISPs location.
Almost forgot, removing phones does not appear to resolve the issue. Removing all phones, of course does (on the specific switch)...but there's nothing plugged into the switch at that point.
David, if you could please do the following
config t
log file debug
log console debug
Additionally, please post a
show run
Also please provide
show run interface fa10  (just a port that has a phone connecting).
-Tom
switch3bb80b#show run
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
interface vlan 1
ip address 10.32.1.10 255.255.255.0
exit
interface vlan 1
no ip address dhcp
exit
hostname switch3bb80b
logging console debugging
logging file debugging
username privilege 15
no snmp-server server
switch3bb80b#
show run interface shows "Empty configuration"
Okay, next time the phones reboot provide the following 2 commands
show log
show log file
Additionally, please choose 1 phone port and do the following
config t
int fa10
negotiation 100f
Choose another phone port
config t
int fa11
negotiation 10h
With these 2 changes, lets see if those 2 phones survive the reboot.
-Tom
Show Log:
04-Dec-2012 13:05:24 :%CDP-W-DUPLEX_MISMATCH: Duplex mismatch detected on interface fa24.
04-Dec-2012 13:04:37 :%STP-W-PORTSTATUS: fa38: STP status Forwarding
04-Dec-2012 13:04:33 :%LINK-I-Up:  fa38
04-Dec-2012 13:04:24 :%LINK-W-Down:  fa38
04-Dec-2012 13:04:21 :%STP-W-PORTSTATUS: fa32: STP status Forwarding
04-Dec-2012 13:04:20 :%STP-W-PORTSTATUS: fa41: STP status Forwarding
04-Dec-2012 13:04:19 :%STP-W-PORTSTATUS: fa5: STP status Forwarding
04-Dec-2012 13:04:17 :%LINK-I-Up:  fa32
04-Dec-2012 13:04:16 :%STP-W-PORTSTATUS: fa8: STP status Forwarding
04-Dec-2012 13:04:16 :%LINK-I-Up:  fa41
04-Dec-2012 13:04:15 :%STP-W-PORTSTATUS: fa2: STP status Forwarding
04-Dec-2012 13:04:15 :%LINK-I-Up:  fa5
04-Dec-2012 13:04:15 :%STP-W-PORTSTATUS: fa42: STP status Forwarding
04-Dec-2012 13:04:14 :%STP-W-PORTSTATUS: fa22: STP status Forwarding
04-Dec-2012 13:04:12 :%LINK-I-Up:  fa8
04-Dec-2012 13:04:11 :%LINK-I-Up:  fa2
04-Dec-2012 13:04:10 :%LINK-I-Up:  fa42
04-Dec-2012 13:04:10 :%LINK-I-Up:  fa22
04-Dec-2012 13:04:07 :%LINK-W-Down:  fa32
04-Dec-2012 13:04:07 :%LINK-W-Down:  fa5
04-Dec-2012 13:04:07 :%LINK-W-Down:  fa41
04-Dec-2012 13:04:06 :%STP-W-PORTSTATUS: fa7: STP status Forwarding
04-Dec-2012 13:04:03 :%LINK-W-Down:  fa8
04-Dec-2012 13:04:03 :%LINK-W-Down:  fa2
04-Dec-2012 13:04:02 :%LINK-W-Down:  fa42
04-Dec-2012 13:04:01 :%LINK-I-Up:  fa7
04-Dec-2012 13:04:01 :%LINK-W-Down:  fa22
04-Dec-2012 13:04:01 :%STP-W-PORTSTATUS: fa26: STP status Forwarding
04-Dec-2012 13:03:58 :%STP-W-PORTSTATUS: fa37: STP status Forwarding
04-Dec-2012 13:03:58 :%STP-W-PORTSTATUS: fa39: STP status Forwarding
04-Dec-2012 13:03:57 :%LINK-I-Up:  fa26
04-Dec-2012 13:03:53 :%LINK-I-Up:  fa37
04-Dec-2012 13:03:53 :%LINK-I-Up:  fa39
04-Dec-2012 13:03:53 :%LINK-W-Down:  fa7
04-Dec-2012 13:03:48 :%LINK-W-Down:  fa26
04-Dec-2012 13:03:46 :%STP-W-PORTSTATUS: fa36: STP status Forwarding
04-Dec-2012 13:03:46 :%STP-W-PORTSTATUS: fa19: STP status Forwarding
04-Dec-2012 13:03:46 :%STP-W-PORTSTATUS: fa12: STP status Forwarding
04-Dec-2012 13:03:45 :%LINK-W-Down:  fa39
04-Dec-2012 13:03:45 :%LINK-W-Down:  fa37
04-Dec-2012 13:03:43 :%STP-W-PORTSTATUS: fa21: STP status Forwarding
04-Dec-2012 13:03:42 :%LINK-I-Up:  fa36
04-Dec-2012 13:03:42 :%LINK-I-Up:  fa19
04-Dec-2012 13:03:41 :%LINK-I-Up:  fa12
04-Dec-2012 13:03:38 :%LINK-I-Up:  fa21
04-Dec-2012 13:03:34 :%LINK-W-Down:  fa36
04-Dec-2012 13:03:33 :%LINK-W-Down:  fa12
04-Dec-2012 13:03:33 :%LINK-W-Down:  fa19
04-Dec-2012 13:03:31 :%LINK-W-Down:  fa21
04-Dec-2012 13:03:27 :%STP-W-PORTSTATUS: fa35: STP status Forwarding
04-Dec-2012 13:03:23 :%LINK-I-Up:  fa35
04-Dec-2012 13:03:15 :%LINK-W-Down:  fa35
04-Dec-2012 13:00:24 :%CDP-W-DUPLEX_MISMATCH: Duplex mismatch detected on interface fa24.
04-Dec-2012 12:55:24 :%CDP-W-DUPLEX_MISMATCH: Duplex mismatch detected on interface fa24.
04-Dec-2012 12:50:23 :%CDP-W-DUPLEX_MISMATCH: Duplex mismatch detected on interface fa24.
04-Dec-2012 12:45:23 :%CDP-W-DUPLEX_MISMATCH: Duplex mismatch detected on interface fa24.
04-Dec-2012 12:40:23 :%CDP-W-DUPLEX_MISMATCH: Duplex mismatch detected on interface fa24.
04-Dec-2012 12:35:23 :%CDP-W-DUPLEX_MISMATCH: Duplex mismatch detected on interface fa24.
04-Dec-2012 12:34:23 :%STP-W-PORTSTATUS: fa38: STP status Forwarding
04-Dec-2012 12:34:19 :%LINK-I-Up:  fa38
04-Dec-2012 12:34:10 :%LINK-W-Down:  fa38
04-Dec-2012 12:34:06 :%STP-W-PORTSTATUS: fa41: STP status Forwarding
04-Dec-2012 12:34:03 :%STP-W-PORTSTATUS: fa8: STP status Forwarding
04-Dec-2012 12:34:02 :%STP-W-PORTSTATUS: fa32: STP status Forwarding
04-Dec-2012 12:34:02 :%STP-W-PORTSTATUS: fa2: STP status Forwarding
04-Dec-2012 12:34:02 :%LINK-I-Up:  fa41
04-Dec-2012 12:34:01 :%STP-W-PORTSTATUS: fa42: STP status Forwarding
04-Dec-2012 12:34:00 :%STP-W-PORTSTATUS: fa22: STP status Forwarding
04-Dec-2012 12:33:59 :%STP-W-PORTSTATUS: fa5: STP status Forwarding
04-Dec-2012 12:33:58 :%LINK-I-Up:  fa8
04-Dec-2012 12:33:58 :%LINK-I-Up:  fa32
04-Dec-2012 12:33:57 :%LINK-I-Up:  fa2
04-Dec-2012 12:33:57 :%LINK-I-Up:  fa42
04-Dec-2012 12:33:56 :%LINK-I-Up:  fa22
04-Dec-2012 12:33:54 :%LINK-I-Up:  fa5
04-Dec-2012 12:33:53 :%LINK-W-Down:  fa41
04-Dec-2012 12:33:52 :%STP-W-PORTSTATUS: fa7: STP status Forwarding
04-Dec-2012 12:33:49 :%LINK-W-Down:  fa8
04-Dec-2012 12:33:49 :%LINK-W-Down:  fa32
04-Dec-2012 12:33:49 :%LINK-W-Down:  fa2
04-Dec-2012 12:33:48 :%LINK-W-Down:  fa42
04-Dec-2012 12:33:48 :%LINK-I-Up:  fa7
04-Dec-2012 12:33:48 :%STP-W-PORTSTATUS: fa26: STP status Forwarding
04-Dec-2012 12:33:47 :%LINK-W-Down:  fa22
04-Dec-2012 12:33:44 :%STP-W-PORTSTATUS: fa37: STP status Forwarding
04-Dec-2012 12:33:43 :%LINK-I-Up:  fa26
04-Dec-2012 12:33:42 :%LINK-W-Down:  fa5
04-Dec-2012 12:33:40 :%STP-W-PORTSTATUS: fa39: STP status Forwarding
04-Dec-2012 12:33:40 :%LINK-I-Up:  fa37
04-Dec-2012 12:33:39 :%LINK-W-Down:  fa7
04-Dec-2012 12:33:36 :%LINK-I-Up:  fa39
04-Dec-2012 12:33:35 :%LINK-W-Down:  fa26
04-Dec-2012 12:33:33 :%STP-W-PORTSTATUS: fa36: STP status Forwarding
04-Dec-2012 12:33:33 :%STP-W-PORTSTATUS: fa12: STP status Forwarding
04-Dec-2012 12:33:32 :%STP-W-PORTSTATUS: fa19: STP status Forwarding
04-Dec-2012 12:33:31 :%LINK-W-Down:  fa37
04-Dec-2012 12:33:30 :%STP-W-PORTSTATUS: fa21: STP status Forwarding
04-Dec-2012 12:33:29 :%LINK-I-Up:  fa36
04-Dec-2012 12:33:28 :%LINK-I-Up:  fa12
04-Dec-2012 12:33:28 :%LINK-W-Down:  fa39
04-Dec-2012 12:33:28 :%LINK-I-Up:  fa19
04-Dec-2012 12:33:25 :%LINK-I-Up:  fa21
04-Dec-2012 12:33:21 :%LINK-W-Down:  fa36
04-Dec-2012 12:33:20 :%LINK-W-Down:  fa12
04-Dec-2012 12:33:19 :%LINK-W-Down:  fa19
04-Dec-2012 12:33:18 :%LINK-W-Down:  fa21
04-Dec-2012 12:33:14 :%STP-W-PORTSTATUS: fa35: STP status Forwarding
04-Dec-2012 12:33:10 :%LINK-I-Up:  fa35
switch3bb80b#
Show Log File:
switch3bb80b#show log file04-Dec-2012 13:10:24 %CDP-W-DUPLEX_MISMATCH: Duplex mismatch detected on interface fa24.
Logging is enabled.
Console Logging: Level debug. Console Messages: 1 Dropped.
Buffer Logging: Level info. Buffer Messages: 200 Logged, 200 Displayed, 200 Max.
File Logging: Level debug. File Messages: 241 Logged, 2318 Dropped.
4 messages were not logged
Application filtering control
Application                 Event                       Status
AAA                         Login                       Enabled
File system                 Copy                        Enabled
File system                 Delete-Rename               Enabled
Management ACL              Deny                        Enabled
Aggregation: Enabled
Aggregation aging time: 300 Sec
04-Dec-2012 13:10:24 :%CDP-W-DUPLEX_MISMATCH: Duplex mismatch detected on interface fa24.
04-Dec-2012 13:08:03 :%AAA-I-CONNECT: User CLI session for user cisco over console , source 0.0.0.0 destination  0.0.0.0 ACCEPTED
04-Dec-2012 13:07:56 :%AAA-W-REJECT: New console connection, source 0.0.0.0 destination 0.0.0.0  REJECTED
switch3bb80b#
Let me know if you need more data from the files.
Unless I missed it, I don't see fa24 going up or down but there is a duplex mismatch. Was port 24 a phone connection you changed the negotiation?
What ports did you change the negotiation on?
-Tom
I believe 24 is actually a small 4 port netgear switch plugged into a copier and an analog fax line converter ATA 186
I used port # 1 for 100 and port # 2 for 10. I am waiting another 15-20 minutes to see if they reboot.
David
David, any luck with reboots?
-Tom
Sorry, was in a meeting.
Port 1 did not go down, port 2 did.
I have switched port 2 to 100f as well to confirm.
Port 2 went down
After further investigation, I noticed that some ports are drawing 2700-3000 mw and some are drawing 5300-5500mw. I suppose some of the phones might be different models (like the receptionist).
Port 1 is drawing: 2700mw
Port 2 is drawing: 5300mw
I went back through the log to see if Port 1 had actually ever went down but the log was truncated so I am unable to confirm.
