CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
520
mrsystemengineer
Beginner
sf 300 intervlan routing
Dear All,
     I used two sf-300 switch and create 4 vlans and intervlan routing is working fine.
Port 1 - 10                   -------------> Vlan 1
Port 2 -20                   ----------------> Vlan 2
Port 3 - 30                 ------------------> Vlan 3
Port 4 - 40                --------------------> Vlan 4
giga1      -----------------> connected to router (This router used for intervlan routing).
SF-300 Port 1 is connected to Internet Modem.  This modem worked as dhcp server also for vlan 1, my problem is that when vlan 1 is not communicate to vlan2,3,4 and 2,3,4 are not communicating.
How i can communicate vlan 1 to 2,3,4 vlan.
Anybody can help me in this issue please.
how i can connect the modem in switch?  Access port or Trunk port ( Presently available in vlan 1 Access port)
              Any route i need to make? sf-300 or modem or router?
regards
1 REPLY 1
Tom Watts
Advisor
This has already been asked and answered. If it is not sufficient, please call the SBSC.
https://supportforums.cisco.com/message/3904221#3904221
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Create
Recognize Your Peers
Polls
How would you describe your level of technical expertise?
