CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here to learn more.
I just purchased an SF300-24 managed switch and I am running it in layer3 mode. I am testing it out right now and have it connected to two 2950 switches. The SF300 is connected to each 2950 with a four port etherchannel running LACP. When looking at spanning tree all three switches are configured the same when it comes to hello, forward, max age and all three are in RSTP mode. I adjusted the priorities so that the SF300 would be the root but that is not happening.
I only have one VLAN as of right now set up and connectivity between the three switches is fine. The only problem seems to be that the two 2950 switches are the only two switches involved in the determination of the root bridge. Additionally it was the same way before I configured the etherchannel and had the switches connected over single trunk lines.
I would appreciate if someone can expain to me why this is?
Thanks in advance.
Hello Michael,
Thank you for using the Cisco Small Business Support Forum. My name is Nico Muselle from Cisco Sofia S-TAC.
Could you verify whether root guard is not enabled on the Catalyst Switches ? Even though you configured the SF300 switch so that it could be elected as root, this option on the Catalyst switches could prevent it from being elected.
You could also monitor STP traffic by doing packet capture of your etherchannel (or LAG on the SF switch). Best way to do this is using port mirroring and use Wireshark so you can analyze what STP packets are exchanged between the SF300 and the catalyst switches.
If you would need any help troubleshooting this issue, please do not hesitate to contact your local Small Business Support center :
https://supportforums.cisco.com/community/netpro/small-business/sbcountrysupport
Best regards,
Nico Muselle
Sr. Network Engineer - CCNA
badge number: C274698
I enabled port mirroring on one of the 2950 switches and on the SF300. When I am monitoring VLAN traffic on the SF300 switch I see no STP packets via wire shark. Even if I change the Priorities on the 2950's to generate traffic. If I monitor the interfaces and not the VLAN it is the same result. When I am monitoring the other end of the Ether-channel on the 2950 side I See the STP packets form the SF300, but never see any sent from the 2950, even when I change the priorities to generate traffic. When I change the Monitoring on the 2950 to monitor VlAN instead of the Ether-channel I see the STP traffic from the 2950 but now do not see any from the SF300. I assume there is a misconfiguration somewhere but I have hit a wall as where to look next.
SF300 Switch:
Spanning tree state: enabled, mode: RSTP, BPDU handling Flooding, Path cost: Long. Prority: 0, Hello Time: 2, Max Age:10, Forward Delay:8,
RSTP Interface Setting:
LAG Point-to-Point enabled, port role Designated, fastlink enabled, port status forwarding
Switch 2950 1
spanning-tree mode rapid-pvst
no spanning-tree optimize bpdu transmission
spanning-tree vlan 2-100 priority 4096
spanning-tree vlan 2-100 forward-time 8
spanning-tree vlan 2-100 max-age 10
interface Port-channel2
switchport trunk native vlan 100
switchport trunk allowed vlan 2-100
switchport mode trunk
switchport nonegotiate
flowcontrol send off
spanning-tree bpdufilter disable
spanning-tree bpduguard disable
spanning-tree guard none
interface FastEthernet0/45
channel-group 2 mode passive
lacp port-priority 1
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
Switch 2950 2
spanning-tree vlan 2-100 priority 20480
spanning-tree vlan 100 forward-time 8
spanning-tree vlan 100 max-age 10
interface Port-channel1
channel-group 1 mode passive
Do you have the Trunking information for the SF 300 switch.
What is the Native VLAN?
Is everything else working?
Everything else is working, I can ping from one 2950 to the other one through the SF300 and can ping all Vlans. The two 2950’s are talking STP between the two of them through the SF 300 but the SF300 just appears to forward it and ignore it.
SF 300 LAG settings:
Type: eth100M, status: UP, Auto Negotiation: enabled, Speed: 100M, Flow control: off, Protection State: Unprotected
LAG Management
LACP: Enabled, Link State: Link UP, Active Member: e21,e22,e23,e24 , Standby Member: none
The other LAG is the same except, Active member:e1,e2,e3,e4
These Settings are the same on both LAGs.
The Native VLAN is 100
I think I might have figured out the problem, please correct me if I am wrong.
The default RSTP on the 2950 is per-VLAN RSTP but
it would appear that the SF300 does not support PER-VLAN RSTP
and I have to use MSTP. Does that sound correct?
Indeed, that was my next question. the Sx300 series switches does not support PVST, it only supports STP, RSTP and MSTP, so that is your issue here. The only way to work around and let the SG300 participate in the STP election is to reconfigure the Catalyst switches to use one of the 3 forms of STP that are supported by the SG300 switch.
Best regards,
Nico Muselle
Thanks for your help but know I still cannot get the three devices to talk MST either,it is getting frustrating. If i add a redundant link and directly connect the two 2950's they immediately talk and configure MST. But when I remove that link no info is passed and both 2950's think they are the root even though the SF 300 priority is 0 on all three MST instances. On the SF300 I have the following settings:
Spanning tree: enabled
STP Operation Mode: Multiple STP
BPDU Handling: Flooding
Path Cost: Long
Region name: test
Revision: 1
Max Hops: 20
Max-age: 20
Hello Time: 2
Forward Delay: 15
MST instance 1 Vlan 100
Bridge Priority 0
Designated Root Bridge: Self
Root port: 0
Root path cost: 0
MST instance 2 Vlan 2-5
Bridge Priority 0
Root port: 0
Root path cost: 0
MST instance 0 all vlans not in instance 1 and 2
Bridge Priority 0
Root port: 0
Root path cost: 0
For MST interface Settings (both LAGs/instances are thesame)
Int Priority: 128
Path Cost: 20000
Port State: Boundary
Mode: RSTP
Type: Boundary
Designated port ID: 128
Designated Cost: 0
Remain Hops: 20
Forward Transitions: 1
The 2950 switches: (The only difference on the other switch is that the priority is 8192, and the MACs of course)
MST00 is executing the mstp compatible Spanning Treeprotocol
Bridge Identifierhas priority 4096, sysid 0, address 000b.460e.e040
Configured hello time 2, max age 20, forward delay 15
Current root haspriority 0, address 6c50.4dcb.334b
Root port is 65 (Port-channel1), cost of root path is 50000
Topology change flag not set, detected flag not set
Number of topology changes 7 last change occurred 00:18:54 ago
from Port-channel1
Times: hold 1, topology change 35, notification 2
hello 2, max age 20, forward delay 15
Timers: hello 0, topology change 0, notification 0
Port 65 (Port-channel1) of MST00 is root forwarding
Port path cost 50000, Port priority 128, Port Identifier 128.65.
Designated roothas priority 0, address 6c50.4dcb.334b
Designatedbridge has priority 0, address 6c50.4dcb.334b
Designated port id is 128.1000, designated path cost 0
Timers: message age 4, forward delay 0, hold 0
Number of transitions to forwarding state: 1
Link type ispoint-to-point by default, Boundary RSTP
BPDU: sent 571,received 568
MST01 is executingthe mstp compatible Spanning Tree protocol
Bridge Identifierhas priority 4096, sysid 1, address 000b.460e.e040
We are the root of the spanning tree
Number of topology changes 9 last change occurred 00:18:55 ago
from Port-channel1
Port 65 (Port-channel1) of MST01 is boundary forwarding
Designated root has priority 4097, address 000b.460e.e040
Designated bridge has priority 4097, address 000b.460e.e040
Designated port id is 128.65, designated path cost 0
Timers: message age 0, forward delay 0, hold 0
BPDU: sent 598,received 0
MST02 is executingthe mstp compatible Spanning Tree protocol
Bridge Identifierhas priority 4096, sysid 2, address 000b.460e.e040
Number of topology changes 9 last change occurred 00:19:50 ago
from Port-channel1
Port 65 (Port-channel1) of MST02 is boundary forwarding
Designated root has priority 4098, address 000b.460e.e040
Designated bridge has priority 4098, address 000b.460e.e040
BPDU: sent 611,received 0
I notice that on MST01 and 02 they are not receiving BPDU’s,but I am not sure why or if that is the problem. It appears that the SF 300 is not sending BPDU packets for MST01 and 02, but is sending them for MST00. I also attached a capture. I captured the VLAN info for VLAN 100 which is in MST1. on the SF300, it appears that the SF 300 is recieving STP traffic but not generating any.
Mr. Couture,
Can you try this. Manually set the bridge priorities on the root switch or the switch you want root and lower the priority to 0 or 4096 and see if that fixes the issue.
This will eliminate the election process and the sf300 switches should submit to the main switch being the root.
Thanks for the input but I have already returned the switch. I was not not happy with the lack of a CLI on the Small Business switches and the limited functionality. Even though I generally prefer the CLI over a GUI, this GUI was just too limited for there not to be a CLI. I figured I would try to save a buck but it was not worth it. I ordered a new 3560, which is what I should have done in the first place.
Thanks again.
No problem.
Thanks for the update.
