11-28-2013 02:23 PM
need help with Vlan's config on a SF300, i have created 5 vlans, the switch is dhcp enabled, created network pools, i assigned one port for testing to vlan 20, but cant get an ip address, dont know if i'm missing something (switch is in layer 2)
basically what i am trying to achieve is that each vlan can obtain an ip address via dhcp and have access to the Internet
any help much appreciated, current config below
switch0ec151#sh run
config-file-header
switch0ec151
v1.3.5.58 / R750_NIK_1_35_647_358
CLI v1.0
set system mode switch
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 10,20,30,40,50
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp server
ip dhcp excluded-address 192.168.168.200 192.168.168.254
ip dhcp excluded-address 192.168.168.24 192.168.168.24
ip dhcp pool network DATA
address low 192.168.168.10 high 192.168.168.252 255.255.255.0
lease infinite
domain-name 192.168.168.254
default-router 192.168.168.254
dns-server 192.168.168.254
exit
ip dhcp pool network Offce B
address low 192.168.170.1 high 192.168.170.254 255.255.255.0
lease infinite
domain-name 192.168.170.254
default-router 192.168.170.254
exit
ip dhcp pool network Office A
address low 192.168.169.1 high 192.168.169.254 255.255.255.0
lease infinite
exit
hostname switch0ec151
no passwords complexity enable
username cisco password encrypted 55c2f525a1900b76e8c633c118ffc2ea8a012277 privilege 15
snmp-server server
ip name-server 192.168.168.254
ip telnet server
interface vlan 1
ip address 192.168.168.253 255.255.255.0
interface vlan 10
name DATA
interface vlan 20
name "Office A"
interface vlan 30
name "Office B"
interface vlan 40
name "Office C"
interface vlan 50
name "Office D"
interface fastethernet11
switchport trunk native vlan 20
exit
switch0ec151#
switch0ec151#
12-03-2013 01:13 PM
anybody any ideas where im going wrong it my config?
12-03-2013 03:04 PM
Hi speedboat, the DHCP feature is for layer 3 mode only. It is why that doesn't work. The additional VLANs not working on the internet would be because whatever the gateway router is, does not understand the VLANs or because they've not been configured correctly.
-Tom
Please mark answered for helpful posts
12-04-2013 01:43 PM
Hi Tom
thanks, i will change it to layer 3, if i configure the switch to give out dhcp, just on one range (192.168.168.x) can i assign dhcp pools to each vlan for example
vlan1 192.168.168.2 - 50
vlan2 192.168.168.51 - 70
vlan3 192.168.168.71 - 100
vlan4 192.168.168.100 - 200
or does each vlan have to have a seperate range and does i have to create a static route for each vlan to my router (draytek 2830n)?
thanks
12-04-2013 04:05 PM
Hi Speed, each VLAN should have it's own respective DHCP.
With that scenario, if your Draytek doesn't support the VLAN, then your Draytek will need the static routes, not the switch.
-Tom
