CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
1955
Beginner
SF 302 Phone and Data on One Port
We recently purchased a SF 302-08P to replace a old 3550 switch.  Is it possible to setup the ports for phone and data?  We have a voice vlan and data vlan.  I can get the phone to work however if I daisy chain the computer off of the phone it will pull an IP from the voice vlan.
I am new to the small business switches and know on the 3550 switches you can set the port for a voice vlan and data vlan, is this possible on the SF 302?
Everyone's tags (1)
3 REPLIES 3
Highlighted
Beginner
Re: SF 302 Phone and Data on One Port
See this post;
https://supportforums.cisco.com/message/3355498#3355498
Also, there is a PDF how-to doc out there that you should look for.  In fact, I think it's posted on the front page.
Here's a document that will help:
https://supportforums.cisco.com/docs/DOC-13573
This document shows how you create the voice VLAN and assign it to the ports. The data traffic is coming into the switch untagged and is put into vlan 1 by default. If you wanted to put the untagged traffic into a different VLAN, create the VLAN and then set it as the PVID on the ports you need to,
Beginner
Yes, that's a good doc right there.  It shows how to configure LLDP-MED+trunking on ports to allow phones to send their tagged frames on one VLAN and the pass-through port data VLAN untagged through the switchport.  This is also applicable to non-Cisco phone solutions as well.
I used this document as an example for integration of our Cisco UC system with Cisco 7900 series phones.
