CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
184
Highlighted
Beginner
SF220 how to remove double login prompt through SSH
SF220 how to remove double login prompt through SSH. its giving issues when trying have NCM in Solarwinds.
5 REPLIES 5
Highlighted
VIP Collaborator
Re: SF220 how to remove double login prompt through SSH
Highlighted
Beginner
Thank you for the reply, but that solution is working for sg300 but not for SF220.
Highlighted
VIP Collaborator
 - Can you provide some 'trail' or screenshots on the manifestation of the double login prompt sequence ?
 M.
Beginner
please find the pic.
Highlighted
First of all i recommend to download the firmware from Cisco URL and upgrade the firmware version on the device.
Please run the below command on switch :
conf t
ip ssh password-auth
and see if it working or not.
It should work in latest firmware version; if it is not running so probably due to lower end model, the command is not available.
Ajay Pareek
