02-25-2013 02:07 PM
I have small problem:
I have 3 VLans
1: Vlan 16 is for management
2: Vlan 2 is for Voice
3: Vlan 4 is for desktop
First port I need for management Vlan 16 and left for desktop+voice (Vlan 2 + Vlan 4) and last - gigabit port fot Trunk. Could you help me with configuration? I do not know how to config - Access mode, Trunk, General etc.
Thank you so much.
Mys
Solved! Go to Solution.
02-25-2013 04:07 PM
Hi Mys, what kind of router do you have? Can you give more information about any network equipment that you have?
-Tom
Please mark answered for helpful posts
02-25-2013 04:07 PM
-Tom
02-26-2013 12:38 AM
Hi Tom,
Connection from provider do Cisco 1841 form Cisco 1841 first port to Juniper SRX220 and second port to Asterisk server.
Thanks.
02-26-2013 04:19 AM
Hi Mys,
For the first port, the port will need to be configured as a trunk port. The native vlan will be 16 (16 untagged) then the vlan 2 and 4 will be tagged. On the GUI the configuration would say 16u, 2t 4t.
To configure this via CLI
config terminal
vlan database
vlan 2,4,16
interface fa1
switchport mode trunk
switchport trunk native vlan 16
switchport trunk allowed vlan add 2
switchport trunk allowed vlan add 4
You made mention of another port but it is not clear what do you want on that port. Do you want to connect a single phone to the port? A single computer? A telephone and computer? The Asterisk box?
-Tom
02-26-2013 09:29 AM
Hi Tom,
23 ports for desktop+voice and Asterisk box is connected to another cisco switch no to new SF300-24p.
Mys
02-26-2013 07:23 PM
Hi Mys, any port using voice vlan + data vlan needs to be configured data vlan untagged, voice vlan tagged.
config t
int fa2
switchport trunk native vlan 4
-Tom
05-14-2015 07:48 AM
I tried it and find out that without native vlan it will not work and once you put native vlan the phone takes the native vlan ip and gives the pc the same ip range.
What I want is that the ip phone will pick voice vlan and give the pc data vlan add.
How do I do the configuration
