CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
1712
Athena1390
Beginner
SF300 CLI - How to change IP, with L3 enabled ?
I have a SF300-48P (Firmware 1.0.0.27).
I wanted to enable L3, and the configuration was renewed (OK, I knew that).
Then, I'm not able to modify the IP : I set it to static, and it kept the IP provided by the DHCP.
There is no way to modify this management IP via the GUI.
I enabled Telnet (SSH cannot be enabled...) and connected via Putty.
But, I have a menu (not the CLI), and I'm not able to change the IP via that menu (error : duplicate IP).
And I cannot obtain the CLI, even when typing Ctrl-Z.
How can I :
- Modify the IP, with L3 enabled
- Have access to the CLI
Thanks in advance for your help.
3 REPLIES 3
V K Moorthy
Beginner
Command line:
switch#config
switch(config)#int vlan 1
switch(config)#ip add 192.168.20.5 255.255.255.0
Try this
Hi, thanks for this answer.
I know that I have to execute this command in the CLI, however the problem is the access to the CLI.
When connecting with telnet, I have a menu, but not the CLI itself.
And I don't know how to switch from this menu to the CLI (Ctrl-Z doesn't work).
Please update the firmware. Cli was not available on this release.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
