10-04-2013 12:55 AM
I have a SF300-48P (Firmware 1.0.0.27).
I wanted to enable L3, and the configuration was renewed (OK, I knew that).
Then, I'm not able to modify the IP : I set it to static, and it kept the IP provided by the DHCP.
There is no way to modify this management IP via the GUI.
I enabled Telnet (SSH cannot be enabled...) and connected via Putty.
But, I have a menu (not the CLI), and I'm not able to change the IP via that menu (error : duplicate IP).
And I cannot obtain the CLI, even when typing Ctrl-Z.
How can I :
- Modify the IP, with L3 enabled
- Have access to the CLI
Thanks in advance for your help.
10-04-2013 01:32 AM
Command line:
switch#config
switch(config)#int vlan 1
switch(config)#ip add 192.168.20.5 255.255.255.0
Try this
10-04-2013 02:30 AM
Hi, thanks for this answer.
I know that I have to execute this command in the CLI, however the problem is the access to the CLI.
When connecting with telnet, I have a menu, but not the CLI itself.
And I don't know how to switch from this menu to the CLI (Ctrl-Z doesn't work).
10-04-2013 06:16 AM
Please update the firmware. Cli was not available on this release.
