SF300 no Ethernet response
fmarshall
Beginner
Beginner
I'm working to configure some new SF300-08 switches.  They are at firmware 1.4.10.6 which I believe is the latest release.
One of them is working fine.  The other, fresh out of the box, updated firmware with the http interface OK but is acting strangely.
I started configuring it via http and then just lost it.
Mostly, the power light is blinking fairly rapidly and the Ethernet ports aren't working.
I can access the console interface OK.  It shows all the Ethernet ports are Up.
How can I get this to recover?
1 ACCEPTED SOLUTION
The LED was always green - blinking or not.
I found the problem and the switch has been configured successfully.
Thanks!
3 REPLIES 3
balaji.bandi
VIP Guru VIP Guru
VIP Guru
As per the document :
The power led flashing continuously is an indication of the default ip address is being used.
quick start guide.
http://www.voipsupply.com/downloads/dl/file/id/151/cisco_300_series_switches_quick_start_guide.pdf
Same trouble at the below link.
https://supportforums.cisco.com/discussion/11764411/sf300-24p-system-light-flashing
BB
Glenn Martin
hello fmarshall,
When did this start? what color is the LED? typically inidicates powering up, acquiring IP Address, or system failure.
If it continues after doing a hard reset you should contact Customer Experience.
Thanks!
