12-26-2015 01:43 AM
I want to select between those two switches for medium business network in terms of reliability,quality, fan noise , bugs.
I dont need fiber channel ,
I will use ip phones
what the best ?
Solved! Go to Solution.
12-26-2015 08:19 AM
2960. The main reason to use the SMB switches would be financial and they are simply not as reliable, unfortunately.
12-26-2015 08:19 AM
12-26-2015 11:20 PM
does 2960 contain auto voice Vlan discovery ?
12-28-2015 08:43 AM
Sure. CDP and LLDP. They just don't use that term 'auto voice vlan discovery', I think.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_55_se/configuration/guide/scg_2960/swlldp.html
