CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
757
Highlighted
Beginner
SF302-08P Won't Import SSL Certificate?
We have seven 300 series small business switches, all consistently configured. All running 1.3.5.58 firmware with 1.3.5.06 boot code.
2x SG300-28P V01
1x SF300-24P V01
1x SF300-48 V01
1x SF300-48P V01
1x SF302-08P V01
1x SF302-08P V02
I have successfully assigned certificates from our Microsoft certificate authority (2008 R2) to five of the units, but can not assign certificates to the two SF302-08Ps.
I use the following commands:
config
crypto certificate 1 generate key-generate 2048
exit
crypto certificate 1 request cn XXX ou XXX or XXX loc XXX st CA cu US
config
crypto certificate 1 import
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
I receive the following error: SSL can't import certificate - conversion of input to certificate failed.
Again, those commands work on five out of seven switches. The only common factor is that they fail on the two small switches.  I have tried rebooting immediately before attempting to generate the key and import the certificate. I tried rebooting immediately before attempting to import the certificate on the existing key. I verify all CSRs and certificates with the utilities here: http://www.sslshopper.com/csr-decoder.html and http://www.sslshopper.com/certificate-decoder.html. I've turned with logging buffer up to level 7 (debugging), but no message is recorded.
Any thoughts on why these two switches won't import my Microsoft CA certificates?
Everyone's tags (4)
3 REPLIES 3
Highlighted
Advocate
Sean, could you email me a sample certificate at tmw0402@hotmail.com ?
I'd like to try to reproduce in a lab to see how my switches behave.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Highlighted
Beginner
Tom,
I have sent you a replay of an effort to generate a CSR and import the certificate issued by our CA. Please let me know if you can reproduce.
Sean
Highlighted
This seems remarkably similar
This seems remarkably similar to my issue: https://supportforums.cisco.com/discussion/12521456/sg300-ssl-certificate-issues-ssl-cant-import-certificate-conversion-input
Did you ever discover what the solution was?
-Zac
