CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
719
renovausr
Beginner
SF302 RADIUS NPS Client IP range
Are Cisco SF300 Series compatible with IP range configuracion in NPS RADIUS server (Windows Server 2016)?
In RADIUS Clients configuration, if I set the IP address of the switch (e.g. 192.168.11.55), I can login successfully. But if I set the IP range in wich the switch is(192.168.11.0/24), login fails.
This configuracion (with IP range) works fine witch Catalyst Switches.
0 REPLIES 0
