SF500 48P - Multiple VLANs and Voice VLAN
alextrieur
I have a SF500-48P switch and and have several VLANs on it (over 25 vlans).
Each of these ports shall support also an IPPhone on vlan 4.
I was thinking about using LLDP so I won't have to setup the VLAN manually on each phone.
But when I do here what's happening,
Original configuration:
Port 25:
Vlan 35 untagged
When I plug the phone, the configuration changes to:
Vlan 1 untagged
Vlan 4 tagged
I was expecting the following:
Vlan 35 untagged
Vlan 4 tagged
Note that ports 1-25 have their own individual VLAN and need to be isolated (already done ACL in the router).
I need help,
regards,
V K Moorthy
step 1:
Go to GUI Menu;
Smartport------>Smartport type settings---->Select IP phone+ Desktop edit  (refer the 11.jpg)
Step2:
Select port type: IP phone + Desktop-----> change the Paramenter Value 1 ( Vlan 1  to Vlan 35)-Refer 22.jpg
regards
Moorthy
What about my other ports that belongs to other Vlans (11-24)?
With the steps you gave me, as soon I connect a Phone, the untagged Vlan becomes 35 for any ports where a phone is connected.
Since I have several Vlans untagged (only 1 per port), I don't want the untagged vlan to be changed by the smartport settings.  Is there a way to do that?
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
