09-14-2009 01:00 PM
Hi, i'm using brand new 1 X SFE2000, 1 X RV082 as router and 2 X WAP2000 with linksys power injectors in my network. I would like to have 3 VLANs. first one would be a management vlan, second an admin vlan and the last one a customer vlan. management would be used for computer tech to manage the equipment. the admin Vlan would be used for all the employees, the AD win2k8 server will be on this vlan too. the customer vlan would be used only to get to the internet. VLan 1 would speak to 2 and 3, but 2 and 3 would not speak to each other. I will relay the AD DHCP server on the 3 vlan. The switch is on layer 3 protocol.
Here is my problem, as soon as i activate the IP access list, the switch is locking up and the only way i can get it to work is to go back to a previous saved config without IP access list activated. i'm activating IP access list with all access to any vlan...and still the same problem... MAC access list is working perfectly.
i'm having the latest firmware...
any advice would be welcome !
thanks alot !
09-24-2009 02:12 PM
I did not change my native/management VLAN. This is not supported. My default gateway is 192.168.11.253. My VLAN 1 is 192.168.11.0/24, VLAN 2 is 192.168.12.254, VLAN 3 is 192.168.3.254. Configured interfaces are e2-5. Do NOT attempt to use ANY/protocol type 255 on the interface. ACL/ACEs are as follows:
permit ip 192.168.3.0 0.0.0.255 192.168.11.253 0.0.0.0
permit ip 192.168.11.0 0.0.0.255 any
permit ip 192.168.2.0 0.0.0.255 192.168.11.0 0.0.0.255
Or the whole config (default login. also attached)
interface range ethernet e(2-4) switchport mode access exit vlan database vlan 1-3 exit interface ethernet e2 switchport access vlan 1 exit interface ethernet e5 switchport trunk native vlan 1 exit interface ethernet e3 switchport access vlan 2 exit interface ethernet e5 switchport trunk allowed vlan add 2 exit interface ethernet e4 switchport access vlan 3 exit interface ethernet e5 switchport trunk allowed vlan add 3 exit interface vlan 1 ip address 192.168.11.254 255.255.255.0 exit interface vlan 2 ip address 192.168.12.254 255.255.255.0 exit interface vlan 3 ip address 192.168.3.254 255.255.255.0 exit interface vlan 100 ip address 192.168.1.254 255.255.255.0 exit ip route 0.0.0.0 0.0.0.0 192.168.11.253 ip access-list ACL1 permit ip 192.168.3.0 0.0.0.255 192.168.11.253 0.0.0.0 permit ip 192.168.11.0 0.0.0.255 any permit ip 192.168.2.0 0.0.0.255 192.168.11.0 0.0.0.255 exit interface ethernet e2 service-acl input ACL1 exit interface ethernet e3 service-acl input ACL1 exit interface ethernet e4 service-acl input ACL1 exit interface ethernet e5 service-acl input ACL1 exit username L1_admin password dcdf2920272f76e823f0633b329881df level 15 encrypted username admin password d41d8cd98f00b204e9800998ecf8427e level 15 encrypted
