05-28-2010 01:13 PM
I am just looking for a clue to switch back the active image to the good one, but I don't have a chance cause it is an intermediate image from a software upgrade and there is no possibility in the CLI because of the continuous reboots.
Thanks for help.
Andreas
Solved! Go to Solution.
05-28-2010 02:08 PM
Hi Andreas,
Even though I am using my SGE2000 as an example i don't think it is different to the SFE2000.
I started hyperterminal at 115200baud as per the setup guide.
from hyperterminal I tried the following, rebooted my SGE2000 and return when it asked me to.
I then had a option to download software via Xmodem.
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................PASS
Flash Image Validation Test.......................PASS
BOOT Software Version 2.0.0.03 Built 18-May-2009 11:44:56
Networking device with CPU based on AXXXXXEJ-S core.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
[2J
Startup Menu
[1] Download Software
[2] Erase Flash File
[3] Password Recovery Procedure
[4] Enter Diagnostic Mode
[5] Set Terminal Baud-Rate
[6] Stack menu
[7] Back
Enter your choice or press 'ESC' to exit:
Downloading code using XMODEM.
If that fails to fix the unit then just call the small business support center via the following URL;
http://www.ciscosystems.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Hope this helps
regards Dave
05-28-2010 02:08 PM
Hi Andreas,
[2J
Startup Menu
[6] Stack menu
[7] Back
Hope this helps
regards Dave
05-29-2010 07:16 AM
Thanks a lot Dave it worked,
While I had my Laptop attached via serial to the device I had seen tis 2 second message
during the reboot cycles and Ionce entered this menu. But I didn't dare to do it. So in ther
meantime I rang the American support hotline and the guy gave me the advice to push the rest
button and power cycle the switch. And when I don't get a stable GUI I should forget the
device and get a new one. This didn't work, so with Your experience I thought this could be
the only chance. I had to press the reset button again and disconnect it from the rest of
the stack (4 devices) cause in the first place the upload via xmodem aborted. It worked on
the other devices as well even though very slowly despite 115200 speed. After connecting the
devices the stack built up again and I could update the firmware and bootloader on all
devices and all images; and it is still working. Just the old config file doesn't seem to
load without errors so there is still a little bit of handwork to do.
Thank You very much again and have a nice weekend.
Andreas
