CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here to learn more.
Good afternoon all,
I have a pair of SG 200-26's acting as an L2 core on a small converged infrastructure. L3 is a pair of virtual PFsense firewalls running VRRP. There are three ESXi hosts (5.1) trunked to the SG 200-26's (one port in each). Northbound are access ports (vlan 5) to a pair of Cisco 3700's. There's a 4 member port-channel trunk between the switches allowing all vlans. The failover issue I am having is with the northbound links. When I reload the primary switch the environment goes dark (it's a remote site). I'm not so familiar with the Linksys webUI on these and I may be missing something. The only substantive change I've made on the switch is the native vlan, I had to change it from vlan 1 to vlan 10 as that is my mgt vlan for the environment. I see the L3 gateway mac (00:26:0b:e0:30:d1) as expected and on the secondary I see it out LAGG2 as expected. Any advice on how to troubleshoot this issue on the SG platform would be wonderful. Thanks so much!!
Wade Blackwell
Hi Wade, a couple things to check would be within spanning tree, ensuring portfast (edge port) did not negotiate on the link. You should also verify the upstream 3700 switches have a lower bridge ID instead of default 32768.
-Tom
Please mark answered for helpful posts
Tom thanks for the reply,
So with edge port hard disabled on both switches northbound (g26), my bridge priorities are 8192 & 16384 respectively. I did get a show spanning-tree from my provider and sure enough the original issue was they were seeing my primary as the root. So with the bridge priorities changed as indicated I am still not failing over correctly. Any input welcome, still testing and reviewing logs for more information.
-W
Are there any standby members within the lags?
-Tom
Nope,
Designated & forwarding or alternate and discarding, as expected.
Anyone? Bueler....Bueler....?
Wade, there's not too much more to discuss on the forum, some things just need a good looking at and I think this is one of them. The SX200 switches aren't anything special, it's just a layer 2 switch. If a link goes down spanning tree should be forwarding the other link. If this is happening on the SX200, you have a problem upstream. It could be as simple as a wire misplaced... but really it's impossible to tell.
I'd recommend you call the SBSC and prepare to give a good couple hours to try to trace the problem step by step.
-Tom
