SG 300 and Cisco Configuration Assistant
sherly_nie
Hi guys I'm having trouble in connecting a SG 300 switch with CCA v3.2. I have already connected the switch with CCA, however I can't see anything in my CCA's Front Panel and Topology view.
Here is the view of my Front Panel view after I connect the switch :
Could you guys please help me to find what the problem is?
Thanks a lot!
rocater
Level 3
Level 3
Hello Sherly,
Have you been able to connect with CCA before? Also, is the switch on the latest firmware?
rocater
Level 3
Level 3
Hello Sherly,
Hi Robert,,
Thanks for your reply. I found out that the problem was caused by the firmware, just like what you said.
I have upgraded the firmware, and now the switch is able to connect properly.
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
