05-11-2012 11:34 PM
Hi guys I'm having trouble in connecting a SG 300 switch with CCA v3.2. I have already connected the switch with CCA, however I can't see anything in my CCA's Front Panel and Topology view.
Here is the view of my Front Panel view after I connect the switch :
Could you guys please help me to find what the problem is?
Thanks a lot!
Solved! Go to Solution.
05-14-2012 06:40 AM
Hello Sherly,
Have you been able to connect with CCA before? Also, is the switch on the latest firmware?
05-14-2012 06:40 AM
Hello Sherly,
05-17-2012 04:57 AM
Hi Robert,,
Thanks for your reply. I found out that the problem was caused by the firmware, just like what you said.
I have upgraded the firmware, and now the switch is able to connect properly.
