CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
838
Beginner
SG-300 and Sonic NSA 2400 speed/duplex settings.
            I have SG300-24 in L2-Mode uplinked to Sonic FW. The only settings that seemed to work  is
100Mb Full-duplex on both sides. If there is any other setting like auto-auto or 1000Mbits on both sides link goes down.
I also set portfast enable on the cisco port. Is there anything I need to check to make 1000Mbits work?
PS: L3 mode did not work for us.
Sree.
2 REPLIES 2
Highlighted
Rising star
Re: SG-300 and Sonic NSA 2400 speed/duplex settings.
Your question doesn't indicate which firmware  version you have running on the switch,.
Please avail yourself of the newest firmware 1.1.2.0 firmware.
Release notes with this new  firmware indicate the following, which may be relevant;
http://www.cisco.com/en/US/docs/switches/lan/csbms/sf30x_sg30x/release_notes/Sx200-Sx300_R1.1.2.x.pdf
Addressed Ethernet interoperability issues with other devices.
- Negotiation command was modified to add an option that allows you to
configure a Gigabit Ethernet interface to operate in either preferred
master or preferred slave mode during negotiation. The option may help
you to resolve interoperability issue that may arise with other device.
The default mode is preferred slave mode.
- The command was modified as follows:
negotiation [capability [capability2... capability5]] [preferred {master | slave}]
regards Dave
Highlighted
Beginner
Thank you Dave. I will test it out and post in forum.
Our switch on latest firmware.
SW version    1.1.2.0 ( date  12-Nov-2011 time  23:34:26 )
Boot version    1.0.0.4 ( date  08-Apr-2010 time  16:37:57 )
HW version    V01
