ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
748
Highlighted
SG-350X not showing the correct LAG speed
I have an SG 350-X stack ( of two switches ) which is connected to a Juniper switch with 6 cables in a LAG group. From the Juniper switch I can see that the LAG speed is 6 Gig,  but from the Cisco side I see only I Gig. Is there any way I can make sure that the LAG on Cisco side is operating at 6G or 1G ? . I did not enable LACP on both sides. The screen shot from Cisco is attached.
5 REPLIES 5
Highlighted
Re: SG-350X not showing the correct LAG speed
My name is Iliya Gatsev from Cisco Technical Support Team.
Are you using SFP or RJ-45 ports on the Cisco switches ? Could you share screen shot from the LAG Management page of the Cisco and from the Juniper if you don't mind ?
Iliya Gatsev
Cisco STAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
Highlighted
hi;
RJ-45 ports on the Cisco switches and Juniper , please find attached requested screen shot.
Regards.
Highlighted
Hello Mohammed,
Can you issue the command in CLI (console or SSH):
switchxxxxxx# show interfaces status
and paste here the output
Highlighted
Hi Mipopov;
please  find below :
PFQ-USER-SW#show interfaces status
                                             Flow Link          Back   Mdix
Port     Type         Duplex  Speed Neg      ctrl State       Pressure Mode
gi1/0/1  1G-Copper      --      --     --     --  Down           --     --
gi1/0/2  1G-Copper      --      --     --     --  Down           --     --
gi1/0/3  1G-Copper      --      --     --     --  Down           --     --
gi1/0/4  1G-Copper      --      --     --     --  Down           --     --
gi1/0/5  1G-Copper      --      --     --     --  Down           --     --
gi1/0/6  1G-Copper      --      --     --     --  Down           --     --
gi1/0/7  1G-Copper      --      --     --     --  Down           --     --
gi1/0/8  1G-Copper      --      --     --     --  Down           --     --
gi1/0/9  1G-Copper      --      --     --     --  Down           --     --
gi1/0/10 1G-Copper      --      --     --     --  Down           --     --
gi1/0/11 1G-Copper      --      --     --     --  Down           --     --
gi1/0/12 1G-Copper      --      --     --     --  Down           --     --
gi1/0/13 1G-Copper      --      --     --     --  Down           --     --
gi1/0/14 1G-Copper      --      --     --     --  Down           --     --
gi1/0/15 1G-Copper      --      --     --     --  Down           --     --
gi1/0/16 1G-Copper      --      --     --     --  Down           --     --
gi1/0/17 1G-Copper      --      --     --     --  Down           --     --
gi1/0/18 1G-Copper      --      --     --     --  Down           --     --
gi1/0/19 1G-Copper      --      --     --     --  Down           --     --
gi1/0/20 1G-Copper      --      --     --     --  Down           --     --
gi1/0/21 1G-Copper      --      --     --     --  Down           --     --
gi1/0/22 1G-Copper      --      --     --     --  Down           --     --
gi1/0/23 1G-Copper      --      --     --     --  Down           --     --
gi1/0/24 1G-Copper      --      --     --     --  Down           --     --
gi1/0/25 1G-Copper    Full    1000  Enabled  Off  Up          Disabled Off
gi1/0/26 1G-Copper    Full    1000  Enabled  Off  Up          Disabled Off
gi1/0/27 1G-Copper    Full    1000  Enabled  Off  Up          Disabled On
gi1/0/28 1G-Copper      --      --     --     --  Down           --     --
gi1/0/29 1G-Copper    Full    100   Enabled  Off  Up          Disabled Off
gi1/0/30 1G-Copper    Full    10    Enabled  Off  Up          Disabled On
gi1/0/31 1G-Copper      --      --     --     --  Down           --     --
gi1/0/32 1G-Copper    Full    10    Enabled  Off  Up          Disabled On
gi1/0/33 1G-Copper    Full    1000  Enabled  Off  Up          Disabled Off
gi1/0/34 1G-Copper    Full    10    Enabled  Off  Up          Disabled Off
gi1/0/35 1G-Copper      --      --     --     --  Down           --     --
gi1/0/36 1G-Copper      --      --     --     --  Down           --     --
gi1/0/37 1G-Copper      --      --     --     --  Down           --     --
gi1/0/38 1G-Copper      --      --     --     --  Down           --     --
gi1/0/39 1G-Copper      --      --     --     --  Down           --     --
gi1/0/40 1G-Copper      --      --     --     --  Down           --     --
gi1/0/41 1G-Copper      --      --     --     --  Down           --     --
gi1/0/42 1G-Copper      --      --     --     --  Down           --     --
gi1/0/43 1G-Copper      --      --     --     --  Down           --     --
gi1/0/44 1G-Copper      --      --     --     --  Down           --     --
gi1/0/45 1G-Copper      --      --     --     --  Down           --     --
gi1/0/46 1G-Copper    Full    1000  Enabled  Off  Up          Disabled Off
gi1/0/47 1G-Copper    Full    1000  Enabled  Off  Up          Disabled On
gi1/0/48 1G-Copper    Full    1000  Enabled  Off  Up          Disabled Off
te1/0/1  10G-Combo-C    --      --     --     --  Down           --     --
te1/0/2  10G-Combo-C    --      --     --     --  Down           --     --
gi2/0/1  1G-Copper    Full    10    Enabled  Off  Up          Disabled Off
gi2/0/2  1G-Copper    Full    1000  Enabled  Off  Up          Disabled Off
gi2/0/3  1G-Copper      --      --     --     --  Down           --     --
gi2/0/4  1G-Copper    Full    10    Enabled  Off  Up          Disabled On
gi2/0/5  1G-Copper    Full    100   Enabled  Off  Up          Disabled On
gi2/0/6  1G-Copper    Full    10    Enabled  Off  Up          Disabled Off
gi2/0/7  1G-Copper      --      --     --     --  Down           --     --
gi2/0/8  1G-Copper    Full    10    Enabled  Off  Up          Disabled Off
gi2/0/9  1G-Copper    Full    1000  Enabled  Off  Up          Disabled On
gi2/0/10 1G-Copper      --      --     --     --  Down           --     --
gi2/0/11 1G-Copper      --      --     --     --  Down           --     --
gi2/0/12 1G-Copper    Full    10    Enabled  Off  Up          Disabled On
gi2/0/13 1G-Copper    Full    10    Enabled  Off  Up          Disabled Off
gi2/0/14 1G-Copper    Full    10    Enabled  Off  Up          Disabled On
gi2/0/15 1G-Copper      --      --     --     --  Down           --     --
gi2/0/16 1G-Copper    Full    1000  Enabled  Off  Up          Disabled Off
gi2/0/17 1G-Copper    Full    10    Enabled  Off  Up          Disabled Off
gi2/0/18 1G-Copper    Full    10    Enabled  Off  Up          Disabled On
gi2/0/19 1G-Copper    Full    10    Enabled  Off  Up          Disabled Off
gi2/0/20 1G-Copper    Full    10    Enabled  Off  Up          Disabled Off
gi2/0/21 1G-Copper    Full    10    Enabled  Off  Up          Disabled On
gi2/0/22 1G-Copper    Full    10    Enabled  Off  Up          Disabled Off
gi2/0/23 1G-Copper      --      --     --     --  Down           --     --
gi2/0/24 1G-Copper      --      --     --     --  Down           --     --
gi2/0/25 1G-Copper      --      --     --     --  Down           --     --
gi2/0/26 1G-Copper      --      --     --     --  Down           --     --
gi2/0/27 1G-Copper      --      --     --     --  Down           --     --
gi2/0/28 1G-Copper      --      --     --     --  Down           --     --
gi2/0/29 1G-Copper      --      --     --     --  Down           --     --
gi2/0/30 1G-Copper      --      --     --     --  Down           --     --
gi2/0/31 1G-Copper      --      --     --     --  Down           --     --
gi2/0/32 1G-Copper      --      --     --     --  Down           --     --
gi2/0/33 1G-Copper      --      --     --     --  Down           --     --
gi2/0/34 1G-Copper      --      --     --     --  Down           --     --
gi2/0/35 1G-Copper      --      --     --     --  Down           --     --
gi2/0/36 1G-Copper      --      --     --     --  Down           --     --
gi2/0/37 1G-Copper      --      --     --     --  Down           --     --
gi2/0/38 1G-Copper      --      --     --     --  Down           --     --
gi2/0/39 1G-Copper      --      --     --     --  Down           --     --
gi2/0/40 1G-Copper      --      --     --     --  Down           --     --
gi2/0/41 1G-Copper      --      --     --     --  Down           --     --
gi2/0/42 1G-Copper      --      --     --     --  Down           --     --
gi2/0/43 1G-Copper      --      --     --     --  Down           --     --
gi2/0/44 1G-Copper      --      --     --     --  Down           --     --
gi2/0/45 1G-Copper      --      --     --     --  Down           --     --
gi2/0/46 1G-Copper    Full    1000  Enabled  Off  Up          Disabled On
gi2/0/47 1G-Copper    Full    1000  Enabled  Off  Up          Disabled Off
gi2/0/48 1G-Copper    Full    1000  Enabled  Off  Up          Disabled Off
te2/0/1  10G-Combo-C    --      --     --     --  Down           --     --
te2/0/2  10G-Combo-C    --      --     --     --  Down           --     --
                                          Flow    Link
Ch       Type    Duplex  Speed  Neg      control  State
Po1      1G      Full    1000   Enabled  Off      Up
Po2         --     --      --      --       --    Not Present
Po3         --     --      --      --       --    Not Present
Po4         --     --      --      --       --    Not Present
Po5         --     --      --      --       --    Not Present
Po6         --     --      --      --       --    Not Present
Po7         --     --      --      --       --    Not Present
Po8         --     --      --      --       --    Not Present
PFQ-USER-SW#
Highlighted
Beginner
Does anybody find a solution for this? I am having the same issue.
