12-16-2016 07:52 AM
Team ,
can we use SFP-10G-SR-S as a transreceiver for a SG 500X switch ?
-BJK
Solved! Go to Solution.
12-22-2016 10:29 AM
Yes, these should be fine.
I would suggest that you raise this question with your Cisco reseller at the time of purchase for added comfort.
12-17-2016 05:10 AM
There is a good explanation here;
https://supportforums.cisco.com/discussion/12583146/difference-between-sfp-10g-sr-s-and-sfp-10g-sr
12-17-2016 05:21 AM
Thanks for responding Matt. I did go through it, yes there doesn't seem to be much difference but none of the Cisco doc states that the SFP-S is compatible with SG-500X. Thats my problem. Coz for one of the projects that I am working on, there is a good number trans receivers required and this SFP-S would bring down the cost considerably.
12-17-2016 07:04 AM
Let me speak with one of my Cisco partners.
When are you looking to order, as I will mostly not be able to speak with them until Tuesday (UK Time)
12-17-2016 09:58 AM
Thanks Matt ! The client might decide next week. Tuesday should be fine. Appreciate the help !
12-22-2016 01:48 AM
Hi Matt / Team,
Any one who could help..
-Bijesh
12-22-2016 10:29 AM
12-22-2016 08:25 PM
Thanks Matt, yup, I got a confirmation that these are compatible.
