04-15-2020 11:34 AM - edited 04-15-2020 11:43 AM
I have a SG110-24HP switch. According to the specs it has 24 Ethernet ports plus 2 SFP ports. => Is that 100% true? Or is it (as I suspect) that the 2 SFP ports are wired in parallel with two of the RJ45 Ethernet ports?
04-16-2020 01:28 AM
- Yes, since these are combo SFP ports , an explanation is provided here :
https://community.fs.com/blog/what-does-combo-port-mean-for-ethernet-switch.html
M.
04-28-2020 05:05 AM
SG110-24HP switch has 24 RJ-45 connectors for 10BASE-T/100BASE-TX/1000BASE-T ports with 2 combo mini-GBIC slots. You may refer the below mentioned data sheet and model comparison links for more details…
https://www.cisco.com/c/en/us/products/switches/110-series-unmanaged-switches/models-comparison.html
