08-06-2019 08:15 AM
I have a new SG250-18 as my new lab core switch. All is well but one port for my access point. Single flat /24 (172.16.30.x) and all is well. This switch has a 2 port LAG over to it's 8 port counter part (SG200-8) to get to the my network edge device and to the Internet. So to illustrate SG200-18 _____2 port LAG____SG250-8____Netgear wireless router___Internet.
Everything attached to either switch is fine except I got a TP Link access point (TL-901ND) for my lab to support 3 wireless clients and when I boot it up, configure with an IP address in the current network, the wireless clients can't get to the Internet. To troubleshoot, I have;
1. disabled\re-enabled STP
2. disabled\re-enabled flow control on the port (giga8) the AP is plugged into
3. Configured a 2nd VLAN, put that port in that new VLAN 2, re-addressed the AP but still can't get out.
08-06-2019 10:10 AM
What is the TP-Link connected to?
Clients getting IPs in the correct vlan/addressing?
08-06-2019 03:35 PM
From the AP can you reach the default gateway of the network?
Does this AP have its own DHCP pool or are the clients getting IPs from the networks DHCP server (presumably switch)?
