CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
4504
Highlighted
Beginner
SG200-26 DHCP-Feature not working?
I bought a SG200-26 switch and wanted to replace some old Netgear switches with it. With the old, simple Netgear switches everything worked. With the SG200-26 the only way to get a connection to the switch is to set the IP address to manual. I want the switch to automatically distribute IP adresses and activated the DHCP feature in the web interface, but it still doesn't work. I also tried to restore it to factory default and updated it to the latest firmware, but this also didn't help. I really prefer the switch to handle this. Any suggestions?
Thanks, Frank
1 ACCEPTED SOLUTION
Highlighted
Enthusiast
Hello Frank,
The 200 series of switches does not have being a DHCP server as a feature.  The 300s and higher have DHCP server as an option on them, but the 200 does not since it is just a layer 2 switch.
If you don't like having to set a static on your PC you can always plug the switch into a network that has DHCP running.  At defaults the switch will pull a DHCP address for itself, then you can check your DHCP server for what address it got and use that for admin access without having to set a static on your PC.
Hope that helps, and thank you for choosing Cisco,
Christopher Ebert - Advanced Network Support Engineer
Cisco Small Business Support Center
*please rate helpful posts*
1 REPLY 1
Highlighted
Enthusiast
Hello Frank,
