05-05-2022 11:03 AM
I've been trying to setup port mirroring to monitor traffic on a port that is experiencing thousands of packet errors to no avail. I've setup the port experiencing the packet errors as the source interface, and the port I want to use to run a packet capture as my destination interface but the status just says "Not Ready" and no traffic is being mirrored.
Does anyone have any advice on what might be wrong?
05-05-2022 11:09 AM
Did you follow any guide? If does not, then try this:
05-05-2022 11:12 AM
Yes, that is the exact guide I followed.
05-05-2022 11:23 AM
Which is your version? This guide mention 1.3.0.62. Should not be this but, just in case.
05-05-2022 11:28 AM
I am on version 1.4.2.4
05-05-2022 11:35 AM
Some additional information in case it's helpful. The port experiencing the issues is part of a LAG and is connected to another switch. It's the only port in the LAG that is getting packet errors. I already tested the cable with a cable tester so I know it's not a bad cable.
05-05-2022 11:45 AM
Maybe that´s the reason. Can you try with a different port just to make sure it works?
05-05-2022 11:58 AM
So I switched it to a different port that is not part of a LAG and can confirm it's working. The Port Mirror status is "Active" and I can see the traffic in wireshark. When I switch it back to the port that was experiencing errors, it goes back to "Not Ready". Is it not possible to mirror a port if it's part of a LAG?
05-05-2022 12:12 PM
Sounds like the problem you are seing on this port may cause the Port Mirroring problem.
Using Web interface I am not sure if possible, but on the CLI I´d recommend to re-configure this port with the command "default interface"
Or you may use a different port instead.
05-05-2022 01:29 PM
Unfortunately the SG200 series switches don't support SSH for management so no CLI.
