07-24-2014 05:49 AM
Is it possible to monitor SG200-50P temperature and FAN status (or each FAN RPM) via SNMP? If yes, which OID's are responsible for monitoring this?
Solved! Go to Solution.
07-30-2014 10:28 AM
Hi Damian,
Those are for fan status. Have not seen the temperature yet but will try to verify and get back to you.
Fans Unit 1 | .1.3.6.1.4.1.9.6.1.101.83.1.1.1.3.67109249 |
Fans Unit 2 | .1.3.6.1.4.1.9.6.1.101.83.1.1.1.3.67109250 |
Fans Unit 3 | .1.3.6.1.4.1.9.6.1.101.83.1.1.1.3.67109251 |
Fans Unit 4 | .1.3.6.1.4.1.9.6.1.101.83.1.1.1.3.67109252 |
Aleksandra
07-30-2014 01:51 AM
Bump. Anyone knows?
07-30-2014 10:28 AM
Hi Damian,
Aleksandra
08-01-2014 03:39 AM
Thanks for answer. About temperature monitoring - I found something like: rl env fan data temp - The unit temperature - 1.3.6.1.4.1.9.6.1.101.83.5.1.1.2.1
Now I'm also searching for OIDs that can show me: total bytes RX / TX and RX errors on LAG interfaces.
08-12-2014 03:00 AM
So I also found RX Packets with Errors on LAG interfaces (which is iso.3.6.1.2.1.2.2.1.14.1000 - iso.3.6.1.2.1.2.2.1.14.1003).
I'm not 100% sure about this 2 OID's below:
RX Total Bytes on LAG if: iso.3.6.1.2.1.2.2.1.10.1000 to 1003
TX Total Bytes on LAG if: iso.3.6.1.2.1.2.2.1.16.1000 to 1003
Can anyone confirm whether this OIDs are properly?
08-18-2014 05:59 AM
Bump...
Can someone confirm if this RX/TX Total Bytes on LAG are properly (or not)?
08-21-2014 10:52 PM
Hi Damian,
I have not done LAB for this yet. But I would suggest you to call Cisco Small Business Support Team and they would be able to assist you:
http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Aleksandra
