CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here to learn more.
Hi team,
I have the following question: Does the SG220-26 support DHCP Relay?
If yes, can you give me the link to the documentation about this command, I have searched many places but still can't find it.
Thank you!
Solved! Go to Solution.
Looking at that document is seems that you need at least an Sx3xxx model
M.
M.
In the following command line reference I did not find a reference to dhcp-relay
