CISCO SWITCHES FOR SMALL and MEDIUM BUSINESS
Introducing the next generation of Cisco Small and Medium Business Switches. Cisco is refreshing its SMB Switch portfolio. Click here  to learn more.
377
Beginner
SG220-26P - 802.3af mode A
Hi all,
I'm about to buy SG220-26P switch. I have some other vendor access point which supports 802.3af mode A.
Does SG220-26P support only mode A or only mode B, or it supports both?
Most important question: will this other vendor access point work with SG220-26P?
Thanks in advance.
8.0af
1 ACCEPTED SOLUTION
Re: SG220-26P - 802.3af mode A
Hi Sir,
The UniFi AP model is compatible with SG220-26P switch.
Puneet Sandel
4 REPLIES 4
VIP Advisor
As per my understand cisco support 802.3AF with max power of 30W.
Mode A is good enough for PoE.
BB
*** Rate All Helpful Responses ***
Highlighted
Hi Sir,
My name is Puneet Sandel and I am from Cisco small business support center.
As per your query, kindly let us know the models of the APs you will be using with the SG220-26P switch.
We will need to check the compatibility matrix for the same also. Regarding the PoE output of the switch, SG220-26P switch supports both 802.3af as well 802.3at PoE standard. Every port can provide you 30W of maximum PoE power. It has a PoE power budget of 180 Watts.
Kindly let us know if you have any other query related to the switch.
Puneet Sandel
Technical Consulting Engineer
Global CX Centers – Small Business Support
Beginner
Access points are UniFi AP AC LITE. Can you please check the compatibility. Thank you.
Hi Sir,
Puneet Sandel
