10-15-2015 12:57 AM
HI,
We have 3 SG220 switches which randomly reboot.
When monitoring these the HTTPS service will stop working then a few days later the switch will reboot itself.
Its on the latest version of code and from what I can see there hasn't been any updates for about a year.
Anyone else had this issue and does anyone know any fixes.
Ross
Solved! Go to Solution.
06-21-2016 01:45 PM
Not sure what's going on, but you should be escalated to the SBSC L2 team and they will provide the image.I'll get to the bottom of this and let you know.
06-16-2016 10:24 AM
Happy to unicast the config to you.
09-05-2018 08:09 AM
06-15-2016 02:21 PM
The CSE at Cisco helping me with my case offered me the beta image. The panics on my switch decreased to about 1 every 35 days after I disabled STP.
06-15-2016 05:04 PM
I have replaced mine with HP switches until they have the code released to fix this. they are waiting on the shelf for the new code....
06-16-2016 09:31 AM
I can't afford this to keep happening to all of our switches. If something doesn't materialize to fix this issue in the next couple of weeks, I'll be forced to dump cisco and move make to HP products for all of our locations.. This has been on-going for about a year now with not a fix. Very very disappointing.
06-25-2016 03:27 PM
Hi, can you send me this beta image file, sistemas@comfacesar.com, thanks
07-16-2016 12:48 AM
We have the same problem, and our experience is the folowing:
- We have not the SNMP Agent de-activated and it crashes anyway.
- We have solved the problem changing the switch (RMA of this switch and buying a new one) but we still have at least 20 switches bought in December 2015 with ths problem, and it is hard to
- We observe that although configuration is retained, time and date is lost in each reset.
- We are going to locate the 1.0.0.20_beta2 firmware and see if it solves the problem.
