Hi - my goal is to configure a private network (I need it isolated to use its own DHCP server, not my cable modem/router DHCP).
I have this setup:
internet connection -> cable modem (192.168.0.0/24) -> wifi mesh router (192.168.68.0/24) -> SG250-08.
The SG250 has port 1 connected to the mesh router, and I have configured a static IP address (192.168.68.103). Anything on the default VLAN1 can access the internet like it was connected directly to the mesh router or using wifi (using default gateway of 192.168.68.1).
I want a second VLAN, let's say 172.16.0.0/24. I create a second VLAN2. I want that VLAN to be able to use the uplink at 192.168.68.103 to access the internet. To do this, my understanding is that I need intervlan routing set up. But I also believe I need something configured so requests to the Internet on VLAN2 uses the link at port 1 to ultimately access the Internet though that default gateway.
I could use some guidance as I don't understand network routing at this level well enough to decipher the documents on how to get this configured.
